need expert advise.....
Palawan Sniper 08
14,000 max rpm same as TK & APPI R-Specs (Cubprix Specs)
</p bro in my experience using appi valve spring on stock bore my snipey could hit 140 top speed..but its only good for racing and drag racing.. my intake valve was replaced bcoz napudpod un dulo..luckily i was able to check nd replaced it b4 it dettached and magkarambola inside..now im using vixion safe for daily use and long ride..its still depends on what set up u nid. sori for bad english
ianghol
did any monster people with monster bike tried LHK valve spring already here?..and can you pls tell me what is the max rpm can it hold..sorry my bad english..thanx monsters:)
kr.r_sniper
maybe tappet clearance bro or the valve set you used is the problem :D me i'm using same Valve Springs (APPI) on my snipy can go 120kph on 3rd gear normal riding position short burst using stage 2 cams & 57mm vixion + 19/22 CMS Valve set :D
kr.r_sniper
thank you papi..:)..oh my God my uncle did put a set of lhk valve spring on my bike..do you have one available papi kr.r?..
try contact other seller i prefer to used CMS/Vi-xion or YYpang Valve springs is available on local market or online sellers...make sure the seller is credible & trusted...
ianghol
monster jval i think doesn't have any by now..:)..BTW papi installing the valve spring doesn't have any procedure?..weather it is up side down?..thank you:D
kr.r_sniper
diy :D make sure do you have plastic cover when you put the valve lock :D or protective sun glasses to protect your eyes :D
towendz
ndi ko pa natest personally yan bro,pero sa tropa namin na naka full mods din yan gamit ok naman depende na lang sa mekaniko na magkakabit
gusto ko nga po itry, pero parang 50/50 pa, kc kalaki ng mura nya compare sa ibang v.springs ee :D
