NEED HELP & ADVISE ABOUT RACING CAMS
vhadz
oops!! napadaan lng..
ive have use this cams, pang asean cam, lhk s1-s2, kawahara k1, s4 evo, no name cam, vixion cam,
valve springs,vixxion, lhk, yypungks,TK, mtrt
clutch springs, mtrt, yypunks,lhk
hehehe don't be ashamed to ask im welling to answers question,, but reminder im not a mechanic just an explorer, wahaha :p
ride safe to all..
vhadz
abot kea ung stock engine q sa xrm na stock lang din.... pero dame acces. niyaya xe q karera e :(
d magets pafs,
pro if race alang binatbat ung xrm, if stock engine s stock engine lng,
if loaded na xrm wala parin..
sa sniper kabit u lng cdi, tangal chock, sibak c raider wampepti at 500m.;)
rowan
ride safe to all..
mr scientist .. mtrt valve spring or vixion.. yy pang ,,w/c is better??
vhadz
wahahaha,
using mtrt stock cam, good, vixxion good, yypang good all are good
using racing cam pls indicate which Rcam are u using,.
wehehe :p
rowan
again mr scientist , buti kpa dami mo natest how about pan asean and faito
need to know kc saan mas mataas na rpm ang ma reach bago mag float
bryanmabaet
d magets pafs,
sa sniper kabit u lng cdi, tangal chock, sibak s 500m ung xrm.. ;)
panu po kc ung HRM mukang mabilis hehe. . . at magaan,
e ung sakin po kc, all stock xa, naka big elbo HGM PIPE lang aq un lang....
pag pinalitan q po ba ng CDI sniper q lalakas xa/??? panu pong tanggal chok?
vhadz
d nmn skin mga hiram hiram q lng,,
havent try faito bro,
6omm rebore block with pan asean cam yypunks given by my cousin from malaysia, result busted!!
best valve for pan asean ill recomend TK, in vixxion valve spring very good but u have to make sure to put enough clerance coz when u reach d top speed then with small clearance or not enough then u well struggle to reach 150-160kph, so if ur using v-valve spring make sure u have that proper clearance, d best to have that tiktik sounds when idle but also feel or listen ( pakiramdaman ) when ur in 3rd gear to 4rth,, ;)
mtrt vsprings 60mm rebore block panasean, dont have to worry even ur clerance is at .005 intake .006 exhaust reaching top speed is no probs more silent than vixxion,.. but still depends in ur taste..
but in other cams this valve spring dont have any problem.. but between d two vspring ill go to MTRT, vixxion vspring'' nice performance but not so good for my taset... but to top it all TK passes my taste even u make small clearance still well give better performance..
im not so familliar with this RPM thing,(bobo aq pgdating jan lalo nat s pagsukat sukat, wehehe,)
but all i know reaching at 140-150 u stay alert coz at that speed its time for reality if ur engine can take it or not.. mine problem occurs when i reached 175kph.. wehehehe :p
vhadz
khit magaan p un bro but still stock engine, results no match
stock to stock kau sure win ka jan..
yup bro changing cdi, well give u more power..
tanggalin mo ung chock ng carb mo... pati ung s loob nito din port and polish mo waaaaaaaaaaaaaaaLaah..
power gain...
rowan
grabe talaga etong scientist angbilis mak 175 na. oo struggling nga kmi to 150 lng .. kaya lng how cod i test eh vixion lit plng kmi d2.diko pa na test ang 60mm...iba talaga dami piyesa ba.
vhadz
d nmn accurate speedo q kasi stock lng, wehehe try u bro go for uma 62.. mga 2nd hand parts lng nmn bro at mga donation ng mga tropa or d kaya patest lng skin,, wehehehe
bryanmabaet
power gain...
okay okay thx po ^_^
