Need some help - How to change gear
r0b0tnik
i mean properly.
my bike is still new, and just done 300km.
however, i find it is hard to change from 1st gear to N.
any tips/tricks to make it work flawlessly?
unlimited express
are you using HC or AC? if its AC then its normal coz its still new. If HC then better squeeze firmly the clutch before gearing down or up.
r0b0tnik
me using Hand Cluth (HC)...
changing to higher gear and lower gears are okay.
only changing gear to N from 1 is very annoying. It is not even mentioned in the manual how to perform the gear change.
hi robotnik
can you explain more detailed?
you are driving motorcycle in first gear... (note your bike is running here not on idle)
then you want to change to Neutral
so you press your clutch and press gear pedal (backfoot) once
to goto neutral.
then what happen,
you cannot proceed to neutral and gear is still in first gear?
edan135
for malaysian lc hc..its all having d same problem..dont turn to N from 1st gear but try from second gear..usually its become easy than drop from first gear..juz my xperience..
unlimited express
I don't get it, how come you can change from 4th all the way down to 1st and you can't change from 1st to neutral? try to push the gear shifter more firmly.
r0b0tnik
Change from 1st -> N is hard, went back to the shop to adjust but still.
I have no problem with this system.
Changing the rest of the gear is no problem
Mine is new extreme edition.
change gear while on running?
or
while you are on idle... ?
because if you are in idle (not running)
changing gears, you need to push forward back your bike
to disengage to another gear, thats normal if you are not running.
r0b0tnik
or
Well, when the bike is idle.
Well, I guess the bike is still new, that's why.
Done my 500Km, not soft break-in or hard break in, just a mixture.. :roll:
proclaimer
Hurm.. Well im using d 135 Extreme Spirit also (HC)... Stil very very new.. Odo 50km++ only.. Hehe.. :)
Same thing happens to me.. Its abit hard to go to N from 1st gear..
There are 2 ways i found out on how to change more easily...
First, for example from 4th gear quickly tap the gear down till N...Works well if u tap the gear fast...
Second, If u are at 1st gear already just tap up the gear till u can feel slight resistance then it will go to N.. But dont tap the gear all the way up coz it then will go back up to 2nd gear.. This method requires some time before you get used to it but so far it works well for me..
Well both the method above works for me... Hope this helps.. Dont kno if the methods are wrong since im new in biking but hey! It works for me.. Hehe.. 8)
guys its normal.
if wheel is not running (idle), its hard to shift from 1st gear to neutral.
you need to turn your wheel.
but that should not be a problem if your bike is running...
salang tm
yes! thanks..
i m also new in this forum..
i try to find the discussion about this ES hand clutch problem..
this also happen to me..i just bought it 2 week ago..
its very hard to change the gear from 1 to N. and it still turn to gear 2.
i think coz this prob..thats why not many people buy the auto clutch lc.
r0b0tnik
umm, its still happening.
now i have to move the bike forward/backward to get to N. Sometimes, when at N, if i engage the gear, it will goes to 2. LOL
salang tm
heheh
u know..when it cannot go to N when i wanna park my 135..i just off it..then when i wanna start it back which it still in gear, i just press the clutch then start it..hahah..
is it can damage my bike?
