New T135 Carburetor
Kaito
New T135 has been launched using Mikuni 25mm carburetor, so I wonder can it be installed on the previous ver T135??? And are they using same TPS socket and cable??? How much will it cost approximately??? Maybe it is a little bit too early to discuss about this :lol:
yes its possible bro.
im 99% sure its plug and play to older bikes.
Mikuni BS25 is the same carb as yamaha nouvo z
or a little bit smaller than Nouvo Elegance BS26 with TPS
For the boys who wants quick upgrade no hassle, this is the easier mods!
for other boys who wants better upgrade, bigcarb slide type is best :D
I will post once i will be able to get a parts catalog...
raider125jeigh
GUYS,
ENGLISH PLEASE
nice one... 25m carb
with tps
i thought the new t135 will have 150cc,
heartbreaker - changing carb will also change gas consumption
if you have stock bore better stay stock or replace jettings
t135 will never changed into 150cc in stock form...because it is T135...not T150...unless u make it higher in cc by applying bored up kit.
inspire
My opinion;
1- It won't have TPS : How large you open the throttel still will depend on dashpot opening (carb's piston valve)
2- It's meant for economy use. Performance use will quickly rupture the rubber diaphragm.
3-Not the same function & response as normal slide-carbs. Need to get used to throttle handling.
This carb works (in simpler terms) by raising the jet needle appropriate to the velocity of air coming through - which is governed by the butterfly throttle. Funny thing with this carb is the fluttering & very rough idle when used with performance high-lift cams. :p :p
Kaito
So does it meant that we can buy Nouvo's carburetor to install it on our bike??? The TPS stuff all plug-and-ply???
raider125jeigh
clydelisboa said:
what do you mean by (slide-type) Carb? is it like the keihin or oko 26mm carb?
it should be flat slide type..meaning the slider inside the carb is flat type..
oko are flat slide type
keihin have flat slide and round type
