New Tricks for Standard CDI
goff_d_p
so the pink wire that gets grounded, is not the end from the CDI, it's from the Harness?
Correct?, is that what your saying syfull?
goff_d_p
ok, well i did tap the wire from CDI to the ground, and i didn't feel any differance in the ride, and my top speed is still the same.
sniper_pink
can anybody show me some video to do thing beautiful things that you share here sir because i dont know what should i really do..please sir..thank you soo much
heloow eveyone................any1 can teach these trick step by step????(for new owner of sniper135)pls..........p.m po.09265893333...t..........iiiiiiiiiiiiii.........aaaaaaaaaaaaaaa
re : trick switch boster
Dear bro,....
i am confiuse to, because i dont know the type switch on the 2nd gear.
look the wiring, ..."33" netral switch.
switch on 2nd gear(33) what type switch ??? NO(normali open) or NC (normali Close) whice one ??. if the switch is NC the "boster status" still active event 3nd and 4nd gear. but if the switch is NO, i think the "boster status" only working 2nd gear.
i want to tray that trick bro...... but i have to know how they work. :lol:
rgds,
sir na tryu nyo na po ba naun ito????share nmn po jan...........t.i.a
guys,ive been using this booster mode set for a while now,n its great fo me!No problem!The performance is better than before..Dont worry,it wont short circuit ur cdi..I think i posted a pic of my moded cdi in the pic gallery somewhere,check it out!Hehe
sir.......help nmn ohhh...try ko din tong akin ,,,,,,,,,pls..
lpsnipie_67
let me get this right...at stock setting,the pink wire just works at '2nd gear' but if grounded(switch ON) the pink wire,our bike are in 'boost mode'..i mean the bike's performance at all gears(1-4)are somewhat increased?if so...im gonna go for it...my CDi is still stock though,i just relayed it directly to battery(mmm..planning to get that REXTOR cdi,have to save some $ first...hehe)
jst ground it to get on all 4 gears!;)
lpsnipie_67
:idea: i have an idea, how bout if the pink cable try to connect with relay where's that relay use 3 connector or 2switch that can be choose with no and nc which the nc will be connect to gear2 and no will connect to gear4 and the center of the switch will be connect with the ping wire cdi.
and as the result by automatically the booster RPM at gear 2 will be use in gear 4 also
is there anyone knows what is the maximum RPM at gear2? :shock:
ground it!
SaM03
its still has no effect, my friend try this... he just ground the pink wire from cdi... still it has a limiter,,,
Kyo Irul
Hi ,
Just share my experience, had done my TPS adjustment - done setting at 0.77v (before 0.54v) to my 135LC version 2 (Super Sport).
Effect - fuel consumption are more efficient and save $$ too... feel the the acceleration increase but Top speed at the same.
Next Step - the pink wire to ground
