jay.frani
hmmm.. kaso wala din akong side stand. gusto ko din balis mga bossing. kaso di ko alam pano ko lalagyan. 2nd owner na kasi ako nung motmot
yves
kung wl k side stand pwede naman center stand lng sk lifter! ang tanung lng jan bro is kung gus2 mo at at kung may budget wl imposible s mekaniko pag sniper bro
suplado010
help poh..nakaHID poh ako tapos ang parklight at signal light ko sa harap is led and all rear light is stock bulb..ok naman siya..but recently nagLED ako ng tail light ang nangyare po kapag nag-ON ako ng ignition may konting ilaw nah po agad yung parklight ko and yung led tail light ko is medjo umiilaw din..ano po kayang problema???tulungan niyo naman poh ako....pls...
up
schmuck
pahelp naman
i have a noob question..swak pa yung rear stock mags ng sniper MX to sniper classic?
usuing the sniper classic stock swing arm..
suplado010
up
tinyvon1617
sir, question po. current mods... racing cam, racing CDI, portnpolish head, stock bore, stock carb(opencarb), racing clutch spring, stock valve spring, open pipe... pwede ko po ba ibalik sa stock CDI kahit naka racing cam ako? or i need need also to put back the stock cam para same as stock po siya? tnx po
schmuck
yup.. kapal ng spacer from the swing arm ang sprocket hub..
and sa other side, bandang rotordisk..
para di tatama ang mga moving objects sa swing arm..
ok papa...pero ok lang gamitin yung stock
swing arm ng classic?
tnx po and ride safe!
jcm1130
yup.. oks na oks naman po stock swing arm natin..
nasa magsasalpak lang yan.. pano nya diskartehin ang mga spacers..
NP bro.. ride safe too..
jangbest
jay.frani paps dito din ako nag palifter, so far so good as far as yves said most of us ClabQ, dito nag palifter satisfied bro!
PM mo nalang si Papa Yves sasamahan ka nyan kaso malayo ka! Binangonan ka pa ata,
Pero bro 2 klase kasi lifter ginagamit natin !!!!
1st is yung ginagamit nang ClabQ guys welded sya, kung safety ang pag uusapan 100 safe toh
2nd lifter is using 2 flatbar, sa safety di ako sure, pero may nagbebenta nyan dito sa T135 si jhay_jhay PM mo din sya.para may choices ka!
3rd is changing your stock Rear, shock to after market shocks like gaz I, racing boy, etc.
jay.frani
ayun oh ayos.. ipon muna konti tsaka isip din, di ata nababalik sa stock e? tama po ba?
jay.frani
dasma cavite lang ako boss. hehehe
magkano naman po ung after market na shox?
cqwuzhere
Hindi naman bro...
@suplado010 check mo head light/park light switch mo bro baka nagloloko na kaya may konting kuryente na tumatalon kaya may konting ilaw parklight /tailight ng mc mo.
ganyan din prob ko sa sniper ko pag naka off parklight ko tapos pag nag break ako umiilaw din yung park light ko kasabay ng tail light.. nagpalit ako ng LED parklight saka tail lights, grounded kaya dahil sa LED tail light ko?
