czar bryan
good day snipey bros..... new lang po... question lang po... anu possible top speed ng stock sniper w/ brt dual band cdi, 15/42, clutch spring & pipe... not bad n po ba ang 125kph.... meron n po ba d2 same set up pero naabot nya 130kph+++.... wat about racing ignition coil it will help po b? ilan m add s speed if i will use it... any suggestion hw to make my spark135t more faster pero stock engine p din..TIA...
Skin gamit ko brt dual band s smx ko nka on yung limiter nya mas mbilis yung acceleration stock pipe at hindi pa ako nagpalt ng valve spring top speed ko is 125 kph ts ko may itataas pa maikisi yung road 14x42 sprocket ko.Mas mganda magpalit ng valve spring tpos protec ignition coil tpos plus + 5 sa mj.Ok kc magpalit ng protect ignition coil mas mbilis mo mkukuha top speed tpos additional 2hp daw kc lumakas kuryente mo basta check lng sp sa burn sbay rejet ng carb.
towendz
sir pag ilaw plang nyan pinapasok na nila sa first gear tapos clutch nlang mag titimpla sa take-off kaya pwede na naka baba ung paa:thumbsup:
hehe sir hindi po ako sa take off curious :D dun po sa 1st to 2nd to 3rd gear.. kumakambyo pero naka baba paa nila :p
crower
san po ba sa nueva ecija or near nueva ecija my marunong tlgang mag install ng hid yun wlng lobat. salamat kng my rereply
towendz
bro bka my kilala k bng ngakakabit ng hid dto un matino sana :D
dun lang bro kay kuya beng.. dun sa papuntang Mcdo pag galing ka ng palengke.. dko kabisado pangalan ng mga lugar dito ee hehe :D Team Beng pangalan nung shop.. kht sa resing magaling un :thumbsup:
WawardTy
Sirs good day,
Just bought a new ignition coil [ProTec] and im wondering what spark plug cap is the best match with this ignition coil?:rolleyes:
I tried disconnecting the stock spark plug cap but im worried i might damage it cause its too tight/hard to pull. :(
Please enlighten me masters.
harrish10
mga paps regarding sa keihin carb throttle cable, anu ba ung bbilin na cable? Png honda xrm ba un? Ung swak po sa sniper naten pg nag keihin carb tau?
rcs05
mga master anu po bang ksma pag ngupgrade ng vixion kit 57mm n block? anu2 po ba ang dpat pang bilhin? pang biyahe lng po gusto kong setup
