JapSpeed
My set: 62mm Bore, Vixion VS, Faito Turbo Cam, 28mm Carb, Mushroom Type Air Filter, Protec Ignition Coil, BRT Dualband CDI, LHK clutch springs, HGM GP Type Big Elbow,19/22 BV, 15/42 sprocket combi....
Before: between 40-48km per Liter
Now: Between 30-34km per liter :confused::confused::confused:
I think that's the down side of having a fast bike, but I never mind...IMHO if you don't like high consumption MC just stay stock...;););)
not bad for 180cc bike... haha... love these mods!
jangbest
...What do you mean "Naka Port ang Head"
I'm planning to install 61mm bore with Stock Head...
Ano ang i modify sa Head?... valve,Valve Spring,at Cams?
Port means lalakihan ang intake ng head luluwangan ang sukat para ma compensate ang additional na diameter ng bore pero much better kung mag big valve ka na katulad nga ng sabi no @kikaipitoy iba padin ang power ng naka big valves unlike sa naka port lang na stock head using stock valves pero option mo lang yun paps ...
Ptr.Jun
Clear... Thanks!
Ptr.Jun
Can I still ride with long distance to that?...
61mm bore, R Cdi, Big valve...
Ptr.Jun
...With these kind of set up... Did you dare to ride Long distance?
Based to your experience,.. how Long? And What is your average Speed? And your speed Limit?
Ptr.Jun
... I don't know how true,
I watched at YouTube ... Sniper converted to 2 stroke, and Mio converted to DOHC.
...is there anyone who knew Sniper SOHC converted to DOHC?
rich_havens
yes, but still sometimes it all depends on how your mechanic set your parts and how you used your bike...
as for me it is tested in long drive... been to:
manila - manaoag pangasinan - manila
manila - baguio - benguet highest point - manila
manila - batangas - manila
manila - tayabas quezon - manila
plus i used my bike as service from home - office - home 26km one way
Ptr.Jun
Wow...thanks for that...I only done long ride at Fully stock...
...what is your speed limit while Long distance? Can you reach 140kph while traveling that far?
rich_havens
since its a group ride average speed is 80-100kph... but when the road is wide and clear plus some other unknown riders you get along and disrespect your bike... (you know what i mean)
you can reach 150 or and more
with regards to gas consumption, a co rider ask me and compare our gas consumption when we went to highest point sand to his surprise we have the same consumption, knowing that his bike is stock while the other is kinda loaded...
Ptr.Jun
Wow... That's great man... Thanks!
Tomorrow is the sched to install my 61mm chrome bore...
Raiden8502
Hi ! I'm from VietNam, sorry i'm not good at English much :)
My bike is Yamaha Exciter 2011 (Sniper - Jupiter Mx 2011), all stock !!!
I have two type of wheel:
---The first one, i use a standard wheel (front: 17 x 1.6, rear: 17 x 2.5), and standard tire (front: 70/90, rear: 100/70) and of course standard sprocket 14-38.
---The second one, i use a Yamaha ZR125's wheel (front: 17 x 1.6, rear: 17 x 1.85), and standard tire (front: 70/90, rear: 100/70) and of course standard sprocket 14-38. The ZR125's is much heavy than the standard wheel. Tire Circum-ference is little bigger than the standard wheel.
My question is, should i use sprocket 14-39 for the second tybe of wheel (ZR125) ?, does it decrease my top speed ?
JapSpeed
I think the 14-38, at 5th gear is about 8400~8500 rpm, and the 14-39, ah 5th gear is about >8500 a little bit, someone told me that, so me be it will increase my top, but i'm not sure.
SMX user here, changing sprocket combination from high speed to low speed will increase top speed... try 14-40, i think this is only applicable for stock engines... it's my own experience...
JapSpeed
Mx ang classic has same ratio in the last gear
i don't think so...
classic
Primary drive = 2.875
34/12 = 2.833
30/16 = 1.875
23/17 = 1.353
23/22 = 1.045
mx
primary drive = 3.042
34/12 = 2.833
30/16 = 1.875
30/21 = 1.429
28/24 = 1.167
26/27 = 0.963
JJ_SMX
.. tanog ko lang poh. kung ano advantage at disadvantage sa performance nang racingboy monoshock compare sa stock na shock. i want to buy po kac for replacement of my busted shock. :) :D
Ptr.Jun
...does the Tensioner of Mio identical or the Same with Old Sniper?
After I install the 61mm Bore there came a sound(lagitik)
It is very hard for me to find Sniper tensioner here at Ilocos Sur....
Is there any Solution? Or can the Tensioner of Mio will function well in Sniper?
...thanks for suggestions and Concern Answer...
