because mine is now charging 15 volts from 14 Volts.. just added some BIG WIRE(once used in automotive grounding kits) to my negative port of my battery and to my Engine..
Proper or standard charging voltage ranges from 14.1 volts to 14.9 volts at Direct Current(DC). This is based on the manual, 15 volts is ok.
About the grounding that is very good idea paps, we can not just relay on the stock groundings of our bike because it only attached to the frame(chassi). thanks for the info. This will prevent intermittent grounding connection on our bikes.
ahh so its all ok if mine is charging 15 volts? coz now im turning ON my HID or park lights everytime i idle or ride it in city. is it ok if i turn it off? my battery wont overcharge?
I miss you too sir traxxas!! congratz on your successful 69!
