ronald031803
when i was running headlight getting out,when i check the bulb its not busted,,and the bettery getting out of charge,,i open the head cowling disconnect the headlight switch then get the yellow with red line wire and put the tester on it,,,,no electric come out...
pls help,is this stator problem?
answer from our master electrician,,,pls
light coil and charging coil i think is separate in the magneto coil not sure agian. most probably the problem is the rectifier because charging and ligthing is running through the rectifier befor going to battery and lightings
