ronnelmarc_21
Paps ronnel question lang, ibig sabihin from magneto na may AC voltage na output regulated na sya? and safe to use for stock lights, even it is not converted to DC?.. hehehe newbie lang paps[/quote:jhge2gb0]the_one said:[quote="ronnelmarc_21":jhge2gb0]Sidro said:[quote="ronnelmarc_21":jhge2gb0][quote="the_one":jhge2gb0]dba kung may prob ung rectifier ko ndi n dpat magstart motor ko?? kso ngagamit ko p kc sya.. testing ko muna batt ni ryioki pra madrain ko rin whahaha..
to check if ur rectifier/regulator is OK,..
1.disconnect the red wire from ur rectifier going to battery and measure the voltage on the red wire and adjust the throtle to change the rpm,..at approc 5000rpm there should be ~13V on it,...otherwise ur rectifier is bad and will not recharge ur battery. NOTE: Red wire has DC voltage
2.Red/yellow AC voltage is ~13Vac at 5000rpm..the regulation for AC from magneto is still OK and still safe to use in lighting "stock wiring"...
Paps yung voltage coming from magneto is AC and it reached more than 100Vac if there is no regulator,...in out MCs the regulator and rectifier is integrated into one,..our stock MC the lighting like headlight is coming from magneto but regulated up to ~14Vac only becoz of the regulator,..so after regulator the AC signal it will go to rectifier,..so the rectified signal that the DC voltage and will be used for charging our battery,...[/quote:jhge2gb0]
so pwede ko parin bng magamit motor ko khit dead n batt ko? wla bng masisirang part pagginamit ko paps??[/quote:jhge2gb0]
OK lang yun paps no worries,..isa lang "it will not recharge ur battery if the output voltage from ur rectifier/regulator is not above 12V.
take note paps,,,mababawasan ang lakas ng motor mo dahil ang CDI natin is sa battery kumukuha din ng power,..try mo obserbahan maigi,..using lobatt and fully charge battery,..more power tlga pag OK ang battery,...
ea364b8][quote="ronnelmarc_21"
nid ko pba bumili ng wire??
