ok po ba feedback ng CMR 61mm block
Sonnyjha
CMR user here over 1year na nagamit wala parin problem..basta double check lang lagi ung Oil Leak everytime na may gagalaw ng block baka kasi poknat ung nagkakabit nagkakaleak ksi minsan pag ndi sanay ung nagkakabit..
Sonnyjha
Repsol Fully Synthetic gamit ko..malakas na ksi mag init pag 61mm na kaya dpat maganda nrin langis ang gamit..chaka ung Coolant ndi narin pede basta mineral water lang..
Sonnyjha
ndi ramdam paps..dpat una set-up PIPE, CDI, Clutch lining at Clutch spring yun may mararamdaman kna dun mura lang nman yung mga yun except syempre pipe at CDI..
transporter
mga master ok po ba feedback ng block na ito gusto ko sna mguograde nito stock engine pa ako at kailangan po ba naka valve springs ako kasi naka stage 2 cams na po ako at kailangan po ba na mg adjust ng jettings sa carb kasi minsan po prang kinukulng sa gas... mraming slamat po sa mga magbabagay ng advice
i was already use 61mm CMR bore up kit, im very happy the power that he gives but i sad to say i got the wrong break in over heat hehehehe. the things that i want to share you got the correct break in thats all...
sniping_area
ang unswa? ok lang yung sa akin... march 2011 ko installed 61mm daily used kung may byahe pwde rin... 61mm, stage2 lhk, port n polish exhaust polish lang yung intake from manifold to chamber, stock carb walang bawas rejet lang, 15/38sproket combi , cooling system half tubig half coolant, yung ibang engine parts stock na... twice na inopen for check up still no leaks still runs good.. last na open yung pagpalit ng lumang valves kasi sira na valves ko b4 pa ako nag 61mm... na worsen dahil sa cams na pina pa try sa amin..tnx to sir job, thops and chiglai sa tips kung pano magtagal yung 61mm cmr :);) yan ang mga hamble masters
odie
sir pede po ba malaman yung mga tips kung pede lang po he he!merry xmas!!!!:)
sniping_area
ok lng bah stock cdi carb lahat tpos naka 61 ka????
stock lang man ko cdi.. cdi, carb, valves, valve spring, clutch spring stock gyud.. kapoy cge gasto... tipid reseng ta...di man gyud ingun nga super kusog ang 61mm di lang ka mabitin sa ubang taas ug cc... :)
