Other Cause Of Oil/coolant Mix
Kershe
posting for a friend.. I already change head gasket and reface head ang block.. And also change the water pump seal set.. But still oil and coolant is mixing.. What is the other cause of this problem?
Engine set is shark 65 bore and 22/24 head
jangbest
Up !!!
snipermxmalayaklan
as other thread said, try taking off your spark plug and crank the engine. If coolant rushed out, still your problem is your head. check if rephase made is perfectly flat, flatten more that head gasket with rubber mallet or level wood and put top and bottom part of head gasket with sealant and lets see what will happen. If you're already done with the prob sir, could you kindly share the prob?
Glymane
Hi sir...newbie here..how many kms should we reach before changing the oil? do we really need to use yamalube oil or what other brands do you recommend? btw smx engine is all stock...thanks in advance for your help
Deigvan Narnia
Hi sir...newbie here..how many kms should we reach before changing the oil? do we really need to use yamalube oil or what other brands do you recommend? btw smx engine is all stock...thanks in advance for your help[/QUOTE
when you reach 500 km, 2000 km, 40oo, or you can refer your manual given by the dealer of your MC,
and its up to you if you use other brand of engine oil its ok no worries, try this engine oil SHELL AX7.
