Pa share na din bout detailed cc computation..
Say sa t135 engine:
Stock Bore: 54.00mm
Stock Stroke: 58.70mm
Mga paps, cc means cubic centimeter or what we called volume
cc formula = pi x (diameter)²/4 x height
pi x (diameter)²/4 = area of circle , where diameter is equal sa bore
height = sa stroke
so if you multiply both (the area and height) magiging volume sya but in cubic millimeters in units kasi mm ang units nakalagay sa taas.
Sample computation sa stock specs..
Cc = pi x (54.00mm)²/4 x (58.70mm)
Cc = 3.1416 x (54.00mm)²/4 x (58.70mm) = 134,435.98cubic mm. (to convert cubic mm to cubic cm, you must divided by 10³ or 1000
Therefore, cc =134,435.98cubic mm/1000 = 134.44 cubic cm or cc
Sana makatulong..
:wink: :wink: :wink:
