Parklight Battery Driven And Headlight Stator Driven Diy Diagram
bhek_21
There are five (5) steps for this installation:
1. Cut the yellow-red (Y/R) wire in the middle. You will now have wires A and B.
2. Cut the Blue-black (L/B) wire in the middle. You will now have wires C and D.
3. Tap wire B to any Brown (Br) wire you can see in your system.
Note: Brown (Br) is different from chocolate brown (Ch). Ch.brown is darker.
4. Tap wire C to positive connection of the Relay. Then tap E to black wire of your system or body as ground.
Note: It's better to buy a relay with socket. If you have socket, there will be an available wire.
Please verify first the diagram of the relay that you will use which is normally drawn at its side.
Red Wire: Positive (#85)
White Wire: Negative (to ground) (#86)
Black wire: Main contact (#30)
Blue & Green: Dry contact (Normally open) (#87 & #87a)
**Tap C to the Red wire (#85) of Relay and tap E (White #86) to black wire of your system or body as ground.
5. Tap A to Black wire (#30) of relay. Then Tap Blue or Green wire (#87 or #87a) to wire D.
Note: The Bosch relay that I bought has normally open contact for both #87 and #87a.
In this configuration, you can use either of the two and secure the one that you didn't use by electrical tape.
Or you can simply short them.:D
Now you can enjoy your battery operated auxiliary lights and your stator powered headlight.
I hope this helps..:thumbsup:
Gie
@Jovic Mark Sabido, sir...tanong ko lang po.. ang SMX po ba naka-direct na agad ang "L" (blue) wire sa "Br" (brown) line? it means battery operated ang aux light ng smx kahit dipa nagagalaw? tulad po ng nasa diagram nyo po, yung nilagyan ko po ng red circle... anyway nice mods po TS...dami matutulungan na mga sniper owner d2 regarding sa convertion ng electrical nila... last year kasi ganito ginawa ko sa sniper classic ko kaya lang lahat battery operated ala kasi ako relay.,.. YAMAHAT135ElectricalDiagram-Copy.jpg
Gie
eto naman po yung ginawa ko, paki-check nalang po sir kung may mali para maayos ko,pero wala pa naman bad effect until now...=) if ever magdadagdag nalang siguro ako ng relay tulad ng mods nyo para stator driven nadin ang headlight ko :thumbsup:
bhek_21
Sir I've already edited this diagram.. that's why..:D But there would be no problem, it's the same principle but it (the one you encircled) is supposedly tapped together with the auxiliary lights on the headlight switch..:D But it's very nice to know that you've seen it, you have a keen eye and observation..:thumbsup: I will post later the correct diagram to avoid confusion..:thumbsup::) Thank you for this sir @gie!:thumbsup: By the way, if you've already done this, maybe you'll just need to add the relay for your stator powered headlight..:)
I've also attached here the original diagram and see the difference..
Note: In the attached diagram, you will notice that the headlight is AHO. So I put a headlight switch on my revised diagram for us to analyze it easily..
Also refer to the picture that I post before and take note of the socket colors and wire color contents..:thumbsup:
Gie
Thanks for the response sir... :) i also noticed there's a typo error on your installation guide... the 2nd one, it should be "C and D"... huhh!!! ang hirap mag-english :oops: anyway sir idol ko na kayo sa electrical.. galing ng mods nyo...hehhee UP UP UP!!!!:thumbsup::thumbsup: OT pla sir, tanong ko nadin how much po bili nyo sa relay?saka ano po yung config? TIA...
bhek_21
Thanks again Bro!:thumbsup: I've already updated the diagram and the typo error..:D
Reminder: YOU ARE ON ENGLISH SPEAKING SECTION, Please post in ENGLISH! <-- ​
that is why my reply to you is in english..:p
The relay I think costs around 150.ooPhp if I'm not mistaked.. Just tell any motorshop that you're looking for a 12VDC relay (BOSCH).. Don't forget to buy also the relay socket..:D
Gie
okey sir... thanks again for the repsonse and i'm sorry for not using english...i forgot this is english speaking section:oops: , my bad..
by the way, is the bosch relay you recommended is the same with the relay that use for bosch horns?
bhek_21
Yes.. that relay is normally used for the horns and other accessories like HID.:thumbsup:
DolF
sir is your head light battery or stator driven?
Gie
@DolF, my head light,park light,signal light are battery driven/operated sir... i just changed my parklight and brake light to LED to lessen the battery consumption. soon i will replace my panel lights to LED...;)
Gie
No prob sir, your welcome. make sure what wire you're going to cut, just refer to Ts's wiring diagram to guide you... Good luck to you sir... and happy modding:dance:
