PART2: NEWBIES QUESTION HERE...
kalipo
wingman44 said:
kalipo said:
jval15 said:
mags painting tips nyo dyan for DIY. ok po ba yung sa spray can? anong magandang brand?
up ko ito.. at panu kung me gasgas yung mags anu dpat gawin?
retouch lang ng paint kung mababaw lang ang mga gasgas.
gasgas ng mga di marunong mgvulcanize e. tadtad. panu b kikinis yun? nid ko bang lihahin yun?
Jval Zkie
tnx! paps kalipo & wingman, mostly kasi ng gasgas sa mags ko caused by vulcanizer. may in can din po ba na primer?
JamesCore
arkhy_sniper135 said:
JamesCore said:
[quote="arkhy_sniper135":2tj0teqj]
JamesCore said:
[quote="arkhy_sniper135":2tj0teqj]Mga paps pag ngRCDI b ko + valve spring+open pipe maimprove p performance and topspeed ni snipee ko?
heres my topspeed wd 15/39 combi +r.Clutch spring
1ST GEAR -40-45
2nd gear-75-80
3rd gear-105-110
4th gear - 120-122.
im 110kgs.. mga paps help kung anu inputs nyo s tanung ko at kung mawawala nb ung "gokgokgok" sound pg cnsagad bwt gear.At lan kea topspeed bwat gear s ganyang set up with 15/39 combi. TIA :)
"gokgokgok" ba paps.. tono mo yung carb mo... ride safe
Nakailang tono nako pafs at ptono s 3s shop pa.. Hangang 45 ung 1st gear parang ngcutcut n ung tunog.. dhl b un s limit ng CDI?
ganun ba.. naka stock cams ka pa sir? kung oo mag llimit sya kasi di naman mahaba duration ng stock cams natin.. idaan mo sa jettings yung main jet gawin mong 105...:D[/quote:2tj0teqj]
paps naka105 na ako.. pag naka open pipe ako e bat bumababa topspeed bawat gear pero topspeed ko meron pa din.. anu ba adjust a/f pag nakaopenpipe mga paps??? TIA :)[/quote:2tj0teqj]
di ko na gets paps "yung bumababa topspeed bawat gear pero topspeed ko meron pa din.."
nikko25
baka pakiramdam nya lng na bumababa topspeed in each gear kasi mas mabilis na makuha ng 1st gear mo ung 40kph o ung limit ng isang gear..kaya pakiramdam mo umiksi topspeed in each gear..
wingman44
@ jval15 / kalipo
kung malalim na ang gasgas sa mags, hindi na pwedeng basta patugan lang ng pintura kasi uka pa rin kahit mapintahan na.
the best ay ipaliha na ng sagad, tapos primer bago pintura.
this way, pantay ang pagkakapintura ng mags
much better, sa talagang pintor na lang ipagawa kasi sa spray paint, halos ganun din magagastos, pagod ka pa. bibili ka ng primer in can, paint in can at clear coat in can.
pareho lang halos ang gastos pero mas maganda finish pag painter talaga ang gumawa
kalipo
wingman44 said:
@ jval15 / kalipo
tingin ko di nga kaya ng basta spray lang yung gasgas ng mags ko.
msyadong matindi pagkabalahura ng ngvulcanizee e.
@ wingman : sir, mga mgkano damage pg ipapagawa ko sa iba to?
wingman44
kalipo said:
wingman44 said:
@ jval15 / kalipo
dapat kasi tubeless na gulong tapos de pasak na lang sa vulvanizing para di na gagalawin ang mags.
pag maganda ang pintura at top coat na gagamitin, mga 1K ang papintura ng mags
pag pulos materials in can ang gagamitin, halos 900 din gastos, ikaw pa ang gagawa
kalipo
wingman44 said:
kalipo said:
wingman44 said:
@ jval15 / kalipo
thanks sir.!!!
pEkz
LoveMeDead said:
mga idol mag 1yr na po kasi motor ko, tanong ko lang po kung na re-renew po ba ang comprehensive inssurance ng motor?
pwede i renew yan paps sa kung san mo kinuha yung previous insurance mo or pde ka humanap ng bagong insurance company..
Jval Zkie
wingman44 said:
kalipo said:
wingman44 said:
@ jval15 / kalipo
maraming salamat sir:)
LoveMeDead
salamat master pekz! renew ko nalang siguro dun sa dati baka mas mura na.. salamat :)
un issue pala na mga gasgas sa motor ko hindi na approve kasi daw msyado mababaw mga gasgas, 5k above na damage daw kasi sabi ng inssurance company.. totoo po ba ito mga papz?
arkhy_sniper135
JamesCore said:
[quote="arkhy_sniper135":93fnhzru]
JamesCore said:
[quote="arkhy_sniper135":93fnhzru]Mga paps pag ngRCDI b ko + valve spring+open pipe maimprove p performance and topspeed ni snipee ko?
1ST GEAR -40-45
2nd gear-75-80
3rd gear-105-110
4th gear - 120-122.
paps naka105 na ako.. pag naka open pipe ako e bat bumababa topspeed bawat gear pero topspeed ko meron pa din.. anu ba adjust a/f pag nakaopenpipe mga paps??? TIA :)[/quote:93fnhzru]
di ko na gets paps "yung bumababa topspeed bawat gear pero topspeed ko meron pa din.."[/quote:93fnhzru]
paps topspeed ng bawat gear ung bumababa... pero topspeed ko sya parin sir...
arkhy_sniper135
ganun nga paps pero tgnan mo namn difference 5-10 kph... from 45-50 sa 1st gear naging 40 lang po.. just want to know more lang po mga kasniper :) Thanks po sa lahat ng sumagot :) i appreciate your advices :) :D :D :D :D
arkhy_sniper135
sir another question..
kaya na kea ng snipee ko ung shogun na ganito specs
shogun bilugan specs:
rcams
racing pin
pipe
rest stock na.
sniper
rcdi
vspring
iridium sp
pipe
rejeted to 105
clutch spring
tia sa infos sir.. yan kasi ang iseset ko sa sniper ko ds coming weeks.. ang nakabit pa lang ai clutch spring at pipe at rejet so far 122 kph topspeed.. sa plus factors keang rcdi vspring at iridium sp dagdag kea topspeed paps???
friendly gauge lang po ung race... :) TIA sirs ans paps :D :D :D :D :D
nikko25
spark plug reading ka bro..anu pipe naka kabit sayo??anu sukat ng elbow?? Try mo pa tono a/f mixture mo..40 kph 1st gear mo??hmm..kaka palit ko lng ng open pipe all stock mc. Ko..so far mas mabilis nga makuha limit speed ng each gear pero di naman bumaba
jamskie
rcams
racing pin
pipe
rest stock na.
sniper
rcdi
vspring
iridium sp
pipe
rejeted to 105
clutch spring
gaano kahaba ang kalsada bro?
arkhy_sniper135
rcams
racing pin
pipe
rest stock na.
sniper
rcdi
vspring
iridium sp
pipe
rejeted to 105
clutch spring
mga 500-700 mtrs po paps
