Petron SAFE (Safety And Fuel Economy) Run 2012
ryioki1
teka teka..meron bang pwdng tawagan or something...parang may mali ung skin eh..tsaka ung consent panu yung...kc nung nagpasa aku sa motorworld eh hnd nmn kasama ung magulang ko...
Undah-Bone
anong mali sayo fafs? hehehe. yung consent sana dinuktor mo nalang tulad ng ginawa ko. nilagay ko name ng mother ko tapos kunwaring pirma. ok na agad diba. hehehe.
ryioki1
hnd ku naicp un eh....eto papadala ko pa ulit...isa pa ung motor x1r un eh...nasa rehistro nmn un nakalagay..
Undah-Bone
kala ko nagpalit ka na eh. hehehe. ok lang yan atleast nakita mo na yung name mo sa list kaso diba 40 participants per class lang ang kukunin? pano kaya yun? ang dami nyo na sa class 3. buti nalang nasa class 1 (SC) ako ngayon. hehe.
Undah-Bone
marami naman waiting din...aayusin ko na agad to bukas..ngyn ko lng nakita ung list eh
pasok na kayo fafs. ito yung post ni sir francis sa kabila. 60 na daw yung max entry sa class 1-3.
Adventure team phil saferun 2012 circular no 9
new classification of entries
motorcycle class
class 1 100-115 60 entries
class 2 116-125 60 entries
class 3 126-150 60 entries
class 4 151-399 25 entries
class 5 400-649 25 entries
class 6 650-899 25 entries
class 7 900-up 35 entries total 290 entries
scooter class
class 1 100-115 55 entries
class 2 116-130 55 entries
class 3 131-299 55 entries
class 4 300-up 45 entries total 210 entries
a minimum of 25 starting participants will be required to declare 3 winners, a minimum of 20 starting participants will be required to declare 2 winners and a minimum of 15 starting participants will be required to declare 1 winner. If a class has less than 15 starting participants, their class will be re classified with the lower displacement class.
The organizer reserves the right to futher reclassify and re allocate entries in order to accommodate as many as 500 riders.
neilryu04
Mga Papz i hope this helps on your ride to Petron SAFE (Tips from the veteran Petron SAFE participants)
For Snipers owners only:
1. Stay Stock tires (70/90 Front - 80/90 Rear *usually old model Sniper O6) : recomemded PSI Front 28 / Rear 32.
2. Stock Craburator, Stock Jettings (cleaned throughly - well tuned)
3. Engine management (follow usually maintenance as per advise by Yamaha)
4. Riders weight is also a factor.
5. Must be familiar with the routes
*As per my experience - with a flat road with strick 60kph speed limit 1 liter is 54 km. my weight is 89kg
latebloomer
for better and fuel economy
increase tire pressure
to the max allowed
Undah-Bone
sa feb.25 na yung PRI. kita kits mga fafs. ito po yung mga titignan sa PRI.
1. HEADLIGHT - dapat po may hi/lo kahit na naka HID kayo. di po nila tinatanggap yung HID na single beam lang.
2. SIGNAL LIGHTS - dapat po color orange lang yung bulb nyo.
3. BREAKLIGHT - tinitignan rin po nila ito.
4. TIRES - kailangan po makapal pa at malalim pa yung linya sa gitna.
5. EXHAUST PIPE - ok lang po yung naka loud pipe as long as na may silencer kayo.
dapat din po naka complete gear na kayo sa PRI. based on experience lang po yan last year mga sir.
Undah-Bone
bagsak ako sa headlight ouch!
single beam lang hid ko...
last year ganun din yung aken kaya after nung PRI umuwi muna ako para ibalik yung stock na headlight, binalik ko din yung stock na pipe at pinalitan yung signal light ko dahil pink yung nakalagay saken.
bili ka lang ng bulb na hi/lo fafs. kay xiatglazz meron 900 ata yun then unting kalikot lang nya para maging hi/lo na yung HID mo.
