pilot jet to 22.5 and Main jet 107 problems after Upgrade
JUNEX
just wanna ask why is it that after i change my carbs main jet to 107 & 22.5 in pilot jet, seems my LC135 can't carry me and my backride. can't run and it shuts off.. can you help me guys what is the possible cause? im a newbie in this stuffs..
goff_d_p
maybe you haven't properly tuned all the new setting together yet. I changed my Main jet, and i had to re-adjust all my other setting, like a/f, idle, spark plug gap, even the tension on my chain made a difference.
blame chiglai :D
bro try to go back to stock jets
and see if it works ok.
fix everthing first...
then once everything is ok
try to change it to the new jets.
chiglai
maybe its bcoz of your sprocket.. try adjusting the tension of your chain.. maybe this might solve the problem.. enjoy...
JUNEX
traxxas-modifier said:
blame chiglai :D
i'll try that trax.. yesterday i've open my valve clearance and herbert "my mechcanic" adjust my valve clearance to 10 and 15? now my LC ran smooth but im worry about my engine because everytime my LC starts it has a tik-tak-tik-tak sound. is it the cams?
hey trax whats the correct valve clearance? IN and OUT..
jamessc77
maybe ur Timing Chain having 'nearing death situation'... the T/C tensioner hard to expand so the T/C guide will hit the tensioner. thats why it sounds like that..when all warm it'll sound lesser, i guest...
blame chiglai :D
the stock valve clearance is
intake = 0.10mm to 0.14mm
exhaust = 0.16mm to 0.20mm
tik tik tik sound is caused by improper valve clearance.
TOO BIG VALVE CLEARANCE
the feller gauge you use is 0.10
so he slides the gauge in and out and feel it...
the mechanic thought his setting is .10
but in reality its not...
the problem here is its in the mechanics discretion
if the 0.10mm is really 0.10mm
due to too small working area in the carb
there will be lots of error...
so trial and error...
JUNEX
hmm ic thanks trax! :D your really i big help!! i'll check my clearance again tomorrow.
i'll buy you a burger @ jollibee, if you visit us soon here in our place! :D
G
goff_d_p35
Guest
that may be due to too low of idel RPM adjustment, sometimes when i was tuning my bike, it would stall. it's just an idel adjustment. ok
Kull
Thanks traxxas, I've receive the MIKUNI JETS .
BTW i have no problem with instaling pilot jet and main jet
to my carb. My LC gain more power.
JUNEX
i found the error!! its not in jet kits nor my carb, engine... ITS IN MY REAR BRAKES! i have tighen my brakes! and when i have a back ride it will brake more.. hehe :D im sooooooo stupid! :D :D now im happy wih my sniper.. :D
chiglai
did you tune your rear brakes? pilot jet and main jet problem connected with brakes? how? help!
botsok
i have changed my jets also with these sizes,. when i suddenly hit the throttle then release it quickly, it seems that the idle lowers until sometimes the engine dies.. and there is a delay on the rev of the engine when i hit the throttle..
