Planning to Change CDI any suggestion please
rhoitol
i dont know .. w8 ill post wat he said..
quote"Saka Sir sakin po naka RCDI ako pero never p ako natukudan ng valves sa piston ko kahit iover rev k p at never kp naexperience magvalve float sa Stock Valve Spring ng (OLD snper ko at SMX ko ngyon) walang kaboom meski isagad2 ko p c Snipee sa Byahe at City Driving tested and proven kuna yan since 2006 up to now", kaya ng Stock Valve Spring Natin ang BRT RCDI", Pangalawang Sniper kuna ito subok kuna talaga ang tibay ng makina ng YAMAHA", san kp sa YAMAHA SNIPER kn hehehe",quote
dats wat he said....
maybe this was a myth...:coffee:
ac_03_taz
mga sir my ask lang po ako pano mgyayari ang valve float kpg ngplit k ng stock cdi into racing cdi
db po mechanical ang barbula tpos yung RCDI electrical po;););)
jcm1130
AKAIK stock cdi limits the valve with a 8500RPM, now replacing the stock cdi with a rcdi will eliminate the limit and valve spring will be in danger coz valve spring can go for only 9200RPM.. imagine the rcdi can reach for about 10000 RPM or more.. this eventually can lead to valve float.. that is why it is advisable to change your valve spring too.. if you will go after a a racing cdi.. although cdi is electrical and valve is mechanical, they tend to work together to improve the performance of the entire engine..:thumbsup:
rhoitol
nice input paps..:coffee:
Paladin
RCDI increases your RPM unlimitedly. Stock valve spring has RPM limit of 9200RPM as sir JCM1130 said. Since RCDI has no limit and stock valve spring has... The result will be valve float. You have two options, change into harder valve spring or limit your RPM cautiously. My suggestion is, change into harder valve spring as well. Why? because your rcdi will be useless if you will not change valve spring.
jangbest
What would you suggest for a brand of valve spring let me say for 1st stage ??????? thanks
Jerick
so whats now? what CDI prefer to use? I'm confuse if i will continue buying the NEW rextor cdi... :(
any update?
xclickclickx
any update?
Use a BRT Dual Band just install a switch if you want to be able to turn your limiters off or on.
its a lot more simple then a rextor its either limited or unlimited.
Jerick
sorry about that...
soo.. what brt should i use for long rides? hyperband or dual band?
sorry for that.
xclickclickx
i dont speak your language im guessing you asked which is better Dual or Hyper...
i would go Dual Band not the Hyper Band......just the Dual Band can be dangerous cause you can rev your bike as far as you want,.. it doesn't have a limiter...but if you cant trust yourself to change gears in time then go for a hyper band and set it at where you would like the rev limiter to be.
you know what i mean?
Hyper band you can set your rev limiter...
Dual Band has not limiter...But you can mount a switch...the switch will turn on you normal limiter and turn off your limiter.
when the limiter is off you will have a blue LED glowing on your front mudgaurd..when you switch it on you wont have a blue LED glowing..
Jerick
i see.. do you have estimation of speed when using both dual and hyper band?
what i mean is, the speed every gear when using brt dual band and hyper band.
sorry for my bad english.
anyway, thanks for this info. :)
xclickclickx
Your English is good,​
im not to sure but Dual Band will Rev more so maybe 11-12500rpm or something so dual band will be faster in the end
but maximum torque range and correct shifting will beat revving on stock yamaha exciters...
the a hyper band you SET RPM hyper band settings will equal different speeds in different gears..
my question for you would you still like to have a limiter?? just at a different setting then factory?
or would you prefer a switch on limit/ off Limit ??​
Jerick
thanks for that.. :)
well that was a nice question.. yeah, I'll go for the cdi that has no limiter.. and you've mentioned that ".just the Dual Band can be dangerous cause you can rev your bike as far as you want,.. it doesn't have a limiter..' well its on the rider's discipline if he wants to rev his motorcycle up to the top. :)
I'll vote for BRT Dual Band.. lots of my friends using this one.
btw.. what other cdi's got busted? my friend's cdi got busted, he is using sniper mx/jupiter mx.. his other friends told me that my friend is always revving his motorcycle wild and free. :D
xclickclickx
yea i think its better cause its up to the rider how he rides..(just dont lend it to your friends!!)
Sorry i dont know what you mean by busted..You mean broken? or busted by the police?
