Please Help!! 62mm Bore Up Problem
Cukel
Hi, i'm from Indonesia. I just had my second problem with my big bore kit. The first time was when I just had a 61mm engine block installed. I think I pushed the bike too hard too early. The bike was making a noisy clicking sound from the engine. Turned out that i damaged the conrod (was using the stock conrod at the time), and also scratched the silinder and piston. So we replaced it with a faito conrod and a new 62mm bore kit. Now it's the same problem. Just happened this evening when i took my bike to 100km/h. Can anybody give me any advice? Is it wrong that I have pushed my bike hard too early after recently installing a new bore up kit? Oh by the way, i use the bike daily (not everyday though), not for race.
Note, these are the parts i upgraded on the engine:
- 62mm piston and engine block
- thicker gasket
- racing valve spring
- faito conrod
- faito racing camshaft
- faito racing crankshaft bearing
- keihin pe30 carburetor
- BRT cdi
- custom CLD exhaust
Please ... Anybody help me, tired of doing the same mistake. Do i really need an oil cooler kit for my bike?
gunkhean
U need to break in your bore kit, & maybe your pilot jet & main jet too lean or the worst possible is ur piston is too tight with the bore. This just my 2 cent.
