Please Help About My Sprocket Combi
janjan
Good Day Members, I just want a little help about my Sprocket Combination. I read few moments ago these previous threads about Sprocket Combination Table, but I'm a bit confused.
I have Sniper Classic with 57 Vixion, 28mm Carbs, Lhk Cams and BRT Cdi but I'm still using a Stock Valve Spring.
My Sprocket Combination is 15 - 39. If you were in my position, what sprocket combination would you choose?.
My weight is 65 lbs.
I want good top speed. Thanks
Hope somebody/someone will help me :dance:
jefplacido
65lbs? almost 30kgs+?:confused::eek:
or 65kgs:rolleyes:
stock tires??
Front teeth | Rear teeth= Gear Ratio
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
15 39 = 2.6 Stock gear ratio
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
so if you want more top speed than stock settings
use 14t front and 36t rear
or 16t front and 41t rear
if you want more acceleration
use 13t front and 34t rear
or 16t front and 42t rear
BIGGER TIRES (100/80 and up): use color red
SMALLER TIRES (80/80 and below): use color green
or try these bro trial and error
15 42 = 2.8
14 40 = 2.86
14 41 = 2.93
if you get better in 2.8 gear ratio then you should try one step lower from 2.8 like
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
Now if on 14 41 = 2.93 you get better performance, then try higher than 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
IMHO credits to the owner
BigBird
or 65kgs:rolleyes:
stock tires??
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
15 42 = 2.8
14 40 = 2.86
14 41 = 2.93
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 44 = 2.93
16 47 = 2.94
15 45 = 3
:thumbsup:
janjan
or 65kgs:rolleyes:
stock tires??
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
15 42 = 2.8
14 40 = 2.86
14 41 = 2.93
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 44 = 2.93
16 47 = 2.94
15 45 = 3
My tire size are
Front 60/80 . Rear 70/80
jangbest
Your lucky that your engine was not exploded ....
Change your valve spring first .. then do your sprocket combi trials .....
ESOJ de GUZMAN JR
its not the sprocket combi. but over rev without replacing stock valve spring. kissing of valve and piston. un sabog ang mangyari sa over rev. 10k lng max rpm ng stock. nka rcdi ka pa man din.
janjan
So if I will use Aftermarket Valve Spring, It will not Valve Float even on high RPM's?.
Im using now RCDI but Stock V. Springs. and I'm really confused about my Sprocket Combi. hehe
ESOJ de GUZMAN JR
Why it will explode sir?. My 15 / 39 sprocket is bad?.
on your weight sir. 15-42 will be the best combi for you. sir ngupgrade ka ng motor mo. bakit d man lng ba sinabi ng mechanic mo na mgpalit ka ng ganito, magpalit ka ng ganyan. afterwards mgtanong ka sa knya. bkt kelangan papalitan. kng marunong sya masasagot nya un. kagaya nyan naikabit na lahat lahat tpos d ka pla ngpalit ng v.s mo. bubuksan ulit head ng mc mo. d bale may problema ka ata d ba. nabasa ko sa kabilang thread. ung black smoke. double check nlng kng san nanggagaling un. good luck.
jangbest
baka di masyadong kabisadi ng mekaniko nya ang MC nya, tsk tsk tsk .....
sakit sa ulo nyan pag nagkataon sana hindi naman .... gud luck @janjan
janjan
or 65kgs:rolleyes:
stock tires??
16 34 = 2.125
15 32 = 2.13
16 35 = 2.19
15 33 = 2.20
16 36 = 2.25
15 34 = 2.26
14 32 = 2.28
16 37 = 2.31
15 35 = 2.33
14 33 = 2.35
16 38 = 2.38
15 36 = 2.4
14 34 = 2.42
16 39 = 2.44
15 37 = 2.47
16 40 = 2.5
14 35 = 2.5
15 38 = 2.53
16 41 = 2.56
14 36 = 2.57
16 42 = 2.63
14 37 = 2.64
15 40 = 2.67
16 43 = 2.69
14 38 = 2.71
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 42 = 2.8
16 45 = 2.81
14 40 = 2.86
15 43 = 2.87
16 46 = 2.88
14 41 = 2.93
15 44 = 2.93
16 47 = 2.94
15 45 = 3
14 42 = 3
15 46 = 3.07
14 43 = 3.07
14 44 = 3.14
14 45 = 3.21
14 46 = 3.29
15 42 = 2.8
14 40 = 2.86
14 41 = 2.93
15 41 = 2.73
16 44 = 2.75
14 39 = 2.79
15 44 = 2.93
16 47 = 2.94
15 45 = 3
Can somebody link me the original post of this kind of table? I think @traxxas-modifier post this. I can't fint the thread. TIA
