Port N Polish Head Assy. with 1mm Shave
adam_john99
Hello everybody, just to share my findings.....i have shaved block and head 1 mm each...no problem at all....chill...but the compression is damn high....
adam_john99
have you tried the psi gauge of your compression?
hye bro....never use psi gauge in my bike but surely i can tell u i am 67kgs weight and i can stand on my kick start lever when i want to start my engine...its damn high compression....good accelaration too....hehhehehehehe
prosper
shaved 1mm on the block and another 1mm on the head? Reliability will be an issue if cranking pressure of cylinder head is to much (unless all out racing). Try to use compression tester if ur dynamic compression is with in limit. I think ur using long duration cam. Avoid too high cr on stock cam or stock compression on racing cam. imho.
adam_john99
so far no problem on startup and running engine....just 1 kick and the engine will start. 1 use the lhk cam no 2 from thailand ever since. no problem on leaking or what so ever.use my bike for daily use since february.
