mark anthony landayan
newbie, ok lang ba gamitn ko to, salamat sa sasagot
I agree with this ...i have tried using this type of coolant this is good but it is not safe if ever the oil seal of the water pump fails and the coolant will mix in the engine oil the metal parts of the engine will corrode so fast specially all bearings much better use Yamaha coolant if ever mix with the engine oil it is not risky unlike this type of coolant. just in my own experience it happens all my engine bearings needs to be replace specially conrod bearing.
nice info!i have tried using this type of coolant this is good but it is not safe if ever the oil seal of the water pump fails and the coolant will mix in the engine oil the metal parts of the engine will corrode so fast specially all bearings much better use Yamaha coolant if ever mix with the engine oil it is not risky unlike this type of coolant. just in my own experience it happens all my engine bearings needs to be replace specially conrod bearing.
