attiado
As long as tama ang pumapasok na hangin sa karburador,pwede yun..hehehe..(TAMA BA YUN mga masters?)hehe tnx sa share nyo sir.. mrmi nq nbsa tungkol sa scotchbrite, hehe .. pero ok lng kaya ung mas maliit na air filter ??
towenddz...hope this can help.. tune up lang yan...ung adjusting knot at screw sa valve may problema yan i pa check mo na sa authorized yamaha mechanic paps....sir wingman problem naman nung akin .. pag mainit na ung engine, habang umaandar pag nagthrottle ng biglaan, or power shift parang nabubulunan ??
anu kya problem ?? spark plug o carb ?
to freyjeff...try mo rin check mo spark plug bka don ung problem...12k odom lang life span ng spark plug ng snipee natin...bka need replaced na...guys,i need ur help...just a newbie here...ahm,last month i changed my pipe with a simple noisy pipe and the problem i am facing now is very bad...whenever i am shifting my gears especially after 3rd gear, the reaction of the engine gets bad...my point is,after shifting,it should be smoothly stabilized the engine reaction..any way my pipe is not a tuned pipe, it was a home made one=)...what do u think would be the problem guys?is it the pipe?and some say,changing of racing cdi will solve the problem?wat do u think guys?need help...
hndi lang don sa tama ng pumapasok na hangin paps.. pati rin sa lumalabas... minsan pag ung engine breather hose din ang mabarahan hndi kna mak patakbo ng mganda..As long as tama ang pumapasok na hangin sa karburador,pwede yun..hehehe..(TAMA BA YUN mga masters?)![]()
unfortunately, if im going to bring back my stock pipe guys, it runs normal...im wondering that my customed pipe is not matched in my engine...but how can i match them then?guys?try to put your stock pipe back.. then you will know if your homemade pipe is the problem...
