Q: Should We Port And Polish Our Snipers?
turbulence
Different mechanics has different ideas about porting our MC, some say that porting increases power, other say that there's no need cause sniper has already have big ports and porting it can decrease top end..... so the big question is, SHOULD WE REALLY PORT OUR SNIPER CYLINDER HEAD? Needed ideas and explanation.
sniper31
Depends on how you do your racing. If drag race or circuit. If drag race, it is advisable to port your engine for a a short boost of power. But for circuit, we call that "sungaw". If you ported your engine, the longer it runs, the more it gets exhausted loosing your last card on final lap. While unported engine reserves it power all the time giving its maximum power the time you needed it the most. (Final lap)
What happens when a low velocity port fills the cylinder really well, but too early ?? The result is a slower intake charge that stops flowing into the cylinder. Then some of the charge gets pushed back out of the cylinder and into the port as the piston returns up the bore during the intake charging phase. The gain in flow doesn't offset the loss in port velocity.
Using the race analogy, if you increase the Port Velocity, by making the port smaller, the intake cycle "race" starts out slower, gains momentum and makes a tremendous charge on the "last lap" to overtake the high flow port and win the "race". The interesting thing is, this type of port will always lose in a flowbench contest !!!
See this pictures of port of r6 vs r1. R1 has smaller port than the r6PortingStockR6.gifPortingStockR1.jpg
rhoitol
See this pictures of port of r6 vs r1. R1 has smaller port than the r6View attachment 16030View attachment 16031
maybe this was Applied Only to Stock Bore, But like us, we Upgraded to bigger bore..
we need to modify our Combustion Chamber to accomodate the additional mm added to the bore..
imagine you have a 57-59mm. if you will not port the stock head, the outcome will be a High compression
and high compresion is good for drag racing and not for everyday use..
vav_mugen524
yup! m agree to roitol. no need to port n'polish if u"ll use in drag race. drag racing need a hi comp to achieve faster accelleration. To solve the problem google search type Homework: How to "HI Velocity Port"- MototuneUSA
READ and APPLY!!! that's my secret of winning.......:thumbsup::thumbsup::thumbsup::thumbsup:
Your stock bore will be faster than 57mm-60mm.
Ginger
intake porting rough no need to polish .. exhaust porting must polish. correct me if im wrong
albert_manio
@ rhoitol.. sir like mine i have 57 mm.. stock head..i use my mc everyday.. do i really need to have p'n' p?
bordz motorshop
no need to port the INTAKE... only the exhaust... as my observation intake porting with stock engine the tendency of affecting the acceleration. the acceleration decreases compared to stock engine with exhaust ported only.
sprinter777
i think stock engine doesnt need head works or porting and polishing..
but modified engine needs it very badly...
port and polish is not simply drilling or enlarging the ports..its state of the art head modification!
it will be your edges from others and your way to be a winner...
be careful when porting sniper dyan nag start ang small holes na hindi kita ng eyes kaya nag hahalo ang tubig at langis if u need a hydroleak test meron ako pang sniper
z_ride13
So make the intake ports near the valve smaller and roughen intake manifold with gas pockets for more funneling to achieve more venturi effect....thus more fuel injection Nice info..Hope I can experiment on this..if time permits..
