(sukiyama)
tnx brosir sukiyama, cant find pics of my carb, but you can check my thread under the t135 riders blog and showbike area, i think i had posted some pics there
nothing... its always itchy daw eh...OT.
whats with your avatar sir sukiyama?![]()
sir thopiang,, ask ko lng if ok lng ba ung hi-lift cams sa stock engine??bakit ako? hahahaha
baka sumabog yan kasalanan ko pa hehehe
cmr 61mm user here for over a year now, had several long rides and daily use . . as in daily kasi motor lang natirang sasakyan ko
kung cum paguusapan este cam hehehe, puede kahit yung may pinaka high lift
yep i thin sir oicat had use high lift cam for his stock engine hehehesir thopiang,, ask ko lng if ok lng ba ung hi-lift cams sa stock engine??
at di nman po ba mlakas sa gas consumption kpag 61mm bore?? TIA..
umm ask ko lng if ano ksma sa kit ng cmr 61mm?? wla po b kelangan i-modify?? kumbga plug and play nman po b sir thopz??meron ata nagbebenta dito sa site nasa 4k ksama shipping
its a kit, so kumpleto na, block, piston, rings and gasketsumm ask ko lng if ano ksma sa kit ng cmr 61mm?? wla po b kelangan i-modify?? kumbga plug and play nman po b sir thopz??
ano po ung packeting the piston?? pano po un sir?? stock n stock pa kc mtor ko..rearset at hgm pipe lng..its a kit, so kumpleto na, block, piston, rings and gaskets
plug ang play? well need fitting kumbaga lalo na pag naka high lift cam ka, need packeting the piston
packeting, kinakalkal yung piston dun banda sa tinatamaan ng valves para hindi magkiss ang valves at piston kc pag nangyari yun, bogsa ang makina heheheano po ung packeting the piston?? pano po un sir?? stock n stock pa kc mtor ko..rearset at hgm pipe lng..
and wla pa nkkaalam mxado mangalikot ng sniper dto sa la union..
so i need a trusted mechanic po.. is there anything na kelngan ng machine shop for poketing sir??packeting, kinakalkal yung piston dun banda sa tinatamaan ng valves para hindi magkiss ang valves at piston kc pag nangyari yun, bogsa ang makina hehehe
thanks bro!copy sir iceman19.
sir sjlu, yep you really need trusted mechanic, and really knows whats hes doing.
ive done my valve packetin myself, am a diy person hehehe, mano-mano lang, lots of trial and error thing
thank you sir thopiang.. how abt 57mm orig yamaha kit.,does it need packeting???copy sir iceman19.
..if you want plug n play go for stage 1 cam^^thank you sir thopiang.. how abt 57mm orig yamaha kit.,does it need packeting???
no trusted mechanic for yamaha sniper here in la union..hehe.. they only expertise on raider,mio,and wave..only a few owns sniper..
so i need a plug and play items if possible sir..i'm not a good DIY..hehe...
hehe.pamin-minsan lng yan sir.wahaha.he..he gling magenglish ni mark ah!!!!!
