Whats the Pros and Cons if you remove your decompression pin?
thopiang Super Veteran Nov 21, 2010 #2 hahaha tagal ko na natanggal yung decomp assy ko, di ko rin alam pros and cons hehehe
makibaoh Super Veteran Staff member Nov 21, 2010 #4 decompression means release of pressure.. if you remove the decompression pin your kick start will be harder to kick compare to stock one..thats the cause of pressure that didnt release..imho.. 8)
thopiang Super Veteran Nov 21, 2010 #6 lam ko tinatanggal yun to prevent possible lost of compression during high rpm pero titigas ang kickstart mo kasi wala ng decomp kung magpapalit ka ng cam, ang ibang cam ay walang butas for decomp pin kaya mapilitan ka tanggalin yung buong assy
raider125jeigh Super Veteran Nov 21, 2010 #7 j-riz said: where is it located? Click to expand... sa HEAD ata yan pafs.
dowaldz New Member Nov 22, 2010 #11 ibalik mo nalang sir yung decompression pin..non sense din kahit alisin mo un..di naman nakakatulong yun..nakakaperwisyo pa..hahaha
JUNEX Super Veteran Nov 22, 2010 #12 @j-riz sa head yan pafs. @thopiang try ko tangaling yung akin.thnx sa pag reply sa thread sir!. @chiglai thnx master! sir patulong po ako sa pag lagay ng fusebox sa cams ko kasi hindi siya umiikot.. thnx! so pag tatangalin yung decomp bibilis yung bike kasi yung compress ay hindi na decompres?
chiglai Super Veteran Nov 22, 2010 #13 dowaldz said: ibalik mo nalang sir yung decompression pin..non sense din kahit alisin mo un..di naman nakakatulong yun..nakakaperwisyo pa..hahaha Click to expand... yes thats right.. para mas mayabang... hahaha
