krux
china r125 saw this bike at makati yesterday.. napeke ako hehehehhee
Product Details
Program information
Type: Motorcycle Racing Fuel: Gas / diesel
Displacement: 125cc Engine type: 4-Stroke
Max. Speed: > 80km / h Certification: EEC
Condition: New Brand: Genata
Place of Origin: China (Mainland) Model Number: GM125YZF-R
Brake (F / R): DISCO Color: Red, green, blue, black, white, silver, yellow
Specs
125cc racing bikes 250cc/200cc/150cc are available for this motorcycle. Water cooled engine is optional, approved by the EEC.
Yzf-r 125cc motorcycle racing, water / oil cooled engine, multiple color are available
motor
Engine Type:
Fmm 165 single-cylinder, 4 stroke, air - cooling, cbb counteract the motor shaft
Bore x stroke (mm):
65.5 & times; 66.2
Idle speed (r / min):
1500
Max. Power (kw / r / min):
6.9/8000
Max. The torque (n. M / r / min):
8.2/7000
Displacement (ml):
125
Max. Speed (km / h):
125
Min consuming fuel (g / km. H)
& Le; 354
Switch:
cdi
From type:
/ Kick electric start
Lubrication:
Pressure splash
Cooling:
Air - cooled
Battery:
7ah/12n7 12v - 3b
body
Transmission:
5 gear international
Brake (f / r):
pump disc brake
Transmission:
drive chain
Minimum turning circle (mm):
4500
Front / rear tire:
110/70-17/130/70-17
Front / rear wheel:
2.75-17/3.75-17
dimensions
Xwxh L (mm):
1960 & times; 730 & times; 1060
Fuel tank capacity (l):
16l
The wheel base (mm):
1340
Turning Radius (mm):
3150
Min ground clearance (mm)
150
Load capacity (kg):
150
The gradeability (& deg
& Ge; 23
Net Weight (kg):
128
Gross Weight (kg):
153
maximum speed
120 Km / h
carton size
x 1870 580 1130 x
others
Cargo containers:
20'GP: pcs 24 40 'GP: 50 pcs 40'HQ: 50 pcs
Product Details
Program information
Specs
motor
Engine Type:
Bore x stroke (mm):
65.5 & times; 66.2
1500
6.9/8000
8.2/7000
Displacement (ml):
125
125
& Le; 354
Switch:
cdi
From type:
Lubrication:
Pressure splash
Cooling:
Air - cooled
Battery:
7ah/12n7 12v - 3b
body
Transmission:
Brake (f / r):
pump disc brake
Transmission:
drive chain
4500
Front / rear tire:
110/70-17/130/70-17
Front / rear wheel:
2.75-17/3.75-17
dimensions
Xwxh L (mm):
16l
1340
3150
150
Load capacity (kg):
150
: & Ge; 23
Net Weight (kg):
128
Gross Weight (kg):
153
maximum speed
120 Km / h
carton size
x 1870 580 1130 x
others
Cargo containers:
