modify your bike to 150 to beat 150cc and riders confidence.Need expert how to beat
r150 stock bore
Stock stroke
Lc135 ?
Please help for set up.
sniper with 57mm,cam,stock ported head,big carb can beat easily STOCK raider...pero ingat kah po sa STOCK MODIFIED raider...yung pang laro nameng raider stock bore , stock stroke nakakasibak ng mio 180cc..recently nakachamba pah sa sniper na open set (si loloy ng sta. maria bulacan) pantayan poh..kaya ingat ingat poh..Need expert how to beat
r150 stock bore
Stock stroke
Lc135 ?
patay kayo jan..depende padin naman poh sa mekaniko e..kung as in stock talaga magagawan niyo na ng paraan para matalo yan..madali lang talunin basta stock talaga..D papi kng stock bore stock stroke tapos
Stock modify ano kya pede ilaban na atlist makakatapat ang sniper.
ako sayo, eto gawin mo. RCAM ka na stage 2 then pocket ur piston, RCDI, Higher RPM range na VSPRING, CLUTCH SPRING, BIG CARB mga 26mm or 28mm much bettter 30mmD papi kng stock bore stock stroke tapos
, lighten flywheel, lighten magneto, lighten balancer, lighten gears, LOW SPEED SPROCKET COMBINATION total drag naman ang laro nyo. RACING IGNITION COIL.
tama, send mo ung engine mo sa kanya set up depends on your budget...yan eh..kaya mahirap kalabanin yung stock bore stock stroke na raider kac balance pa yung lamang loob..lam ko c TS laki na ng bore eh pero kung parehasin na stock..magapagawa ka na kay kimredbull..ayun bka sakali mtalo yung raider![]()
super agreee...Magirap kalaban ang raider na stock bore stock stoke the rest open modify lalo na pang breed wars ang setup
tanong lng....ano un lighten flywheel????san nakalagay stock nyan?iba b yan sa balancer??ako sayo, eto gawin mo. RCAM ka na stage 2 then pocket ur piston, RCDI, Higher RPM range na VSPRING, CLUTCH SPRING, BIG CARB mga 26mm or 28mm much bettter 30mm, lighten flywheel, lighten magneto, lighten balancer, lighten gears, LOW SPEED SPROCKET COMBINATION total drag naman ang laro nyo. RACING IGNITION COIL.
PWDE NA YAN PANG SIBAK NG RAIDER NA STOCK.![]()
same lang poh ang flywheel at balancer IMO..natatagpuan poh ito sa right crankcase naten..tanong lng....ano un lighten flywheel????san nakalagay stock nyan?iba b yan sa balancer??
ok alam ko un balancer,nalilito ako sa dlwa magkaiba ng name iisa lng pla..tnx sirsame lang poh ang flywheel at balancer IMO..natatagpuan poh ito sa right crankcase naten..
hahahahaha. nahihiya naman akong mang hindi. wala namang pustahan eh. hahaha. ok lang yan. sisibakin ko yan next time. whehehehehaha..ayun c jiou natalo kahapon sa raider na stocklam nmn na d nka cdi inon d spot pa
tuloy tatlong motor agwat..
bawi nlng next week
