Racing Boy products for sale
G
goff_d_p35
Guest
Mars bro, There are 3 different versions...first two are for rear wheel drum: 1st will b 1.6 front 1.85 rear an 2nd will b 1.85 front n 2.15 rear... these 2 are for drum brakes... the third version is for disk rear wheel brake, size is 1.85 front 2.50 rear, only for front and rear wheel disk brake's
blue308
Hi lc, Newbie here looking to add some mods to a 2008 sniper.
What is the widest rim and tire size (front and rear) that can be put on a stock sniper without making modifcations?
Please pm the prices for:
811 Sport Rims F 1.85 R 2.5
Dunlop 900TT tires 80/90, 100/80, 110/70(if available)
LC 135 Rear brake system
300mm
LC Racing Footrest version2
include shipping to the philippines.
thanks
G
goff_d_p35
Guest
the biggest tire you can put on the stock rim is F-90/80, r-110/80.
the 90/80 f is tight in the fender and does rub some.
blue308
Thanks goff,
How 'bout rim sizes/widths, with those tires will I have any problems (fitment/clearance on stock forks & swingarm) using the F 1.85 , R 2.5 wheels. I'm thinking about going with the Racing Boy 811's and converting to the disc brake setup.
G
goff_d_p35
Guest
with the wider rims, you can still only go 90/80 in the front, unless you change your tree that attaches the fork to the bike to be wider. on the back i believe the widest you can go is 130 for the 2.5 rim. and that may not fit into the stock fender. if you want to keep stock fender then just stick to 110. ok bro
don't forget, bigger tires, and rims may cause your bike to loss top speed, so you may also want to look for a better sprocket and chain combo.
blue308
cool, thanks bro for the info. I'll stick with what works in the stock fork and swingarm. Just waiting on LC to get some prices to me. So maybe F 90/80 and R 110/70 (if available) or 80/80 100/80.
Planning to go +2 on rear sprocket to help out a little with the new rims and tires. Maybe a lighter chain also.
lc-motospeed
@blue308
pm sent... by the way, ur chain combination if u use 90/80 110/70 tyres should b nice wif 14/38... tat was wat i had on my bike, was using 14/36 n my bike felled very heavy after i changed to the 1.85,2.50 rims wif the tyres mentioned above but after changing the rear sprocket up by two, ah, bike feels so much better =)
G
goff_d_p35
Guest
I know Traxx recommended to me with bigger tires, the 16f/42r tooth combo. But i'm having trouble finding that combo.
lc-motospeed
16/42 will b almost similar to 14/37 n 39/15... slight difference in the ratio but u'll get somewhere almost similar to 16/42 so u could try tat out if u can't get 16/42 sprockets =)
lc-motospeed
here's my latest shipment tat'll b heading to greece for 1 of the forumers over here =) should b leaving in 2 days from the day i posted tis
list of items consist of:
4 sets of vixion/fz150i block n piston set
4 sets of complete gaskets
4 sets of yy pang racing cam n valve springs
2 sets of ori yamaha side mirrors
1 ori yamaha headlight assy
1 racingboy fork stabilizer
1 2nd hand stock block n piston set (mine)
lc-motospeed
shipment to another forumer from s'pore
list of items:
2 shark 60mm block n piston set
2 sets of yy pang racing cam n valve springs
1 2nd hand andrion coil (mine)
1 2nd hand yamaha thai swingarm (mine)
pics for andrion coil n swingarm not available s its still on my bike n still not removed =P
