Hi Bro,
Went to big bore recently, and its power went up probably around 16plus hp or more (looking at 150cc U/B which is around 16hp except two stroke). So its a lot of improvement, as for the big valves head kit there are some but the price is astronomical!!! because you will buy a kit with orig cyl head with big valves!
The bore kit consist of a orig block with sleeve, milled piston, piston rings, bush sleeve for the piston pin. You have to buy a piston pin from a Lifan 110.
For the racing CDI I'm using a Kitti XBOX you can pm me for more details. HTH
