Racingboy Questions and Aswers Thread
drew_sniper
mga sir.. im planning to upgrade my stock mags into racingboy mags 8spoke.. kaylangan ko ba ilipat ung stock bearing and bushing ng stock mags ko sa racingboy mags ko. please need some advice..
y4stroker
NEW RACING BOY RIM IN TOWN!!! :twisted:
Racing Boys engineering uses Computer Numerical Control or CNC technologies combined with Computer Aided Design (CAD) to precisely lathe and mill each raw shaped rim forging into a one piece sports rim.
Rim Sizes: [160 X 17] + [185 X 17] + [highlight=red][215 X 17] + [275 X17][/highlight]
hell boy
hindi ba ito yun 65000.00 na naka display sa cyclone?.. grabe kala mo gawa sa ginto.. napanganga na lang ako sa presyo...
abcdef
hi recently installed a koso uma racing meter and encountered some problems. after turning on the bike, meter panel show r5 error and needle move up from 0-15rpm very slowly. top right corner of the meter display voltage for the first 4 page never display time. what could be the problem? wrong cable connection or meter faulty?
john_carlo
wrong connection i think if error r5 in every on of the MC.. about the time it cannot show the time, temp, voltage at the same time youl only choose one of the three in on mode just press and hold the setting button until the time chage to temp the voltage then time agian
sniperd
images.jpgmasters need help, where can I buy that brake peg with brake rod also the clutch shifter... for racing boy rearset version 2... thanks in advance.
guitarizta
Hi, is there anybody here who experienced the SP811 1.85 rear mags is not totally centered? its a little bit on the left side that is why my rear tire is hitting my stock inner fender when I have a backride. My setup is RB Brake kit, RB SP811 Mags 1.6f/1.85r on Stock swingarm and RB Monoshock. All of the spacers of RB brake kit were installed where they should be based on the diagram of @john_carlo . I am thinking that maybe purchasing a RB swingarm will fix my problem but I'm not 100% sure about that. The RB swingarm is a little bit pricey so I have to be 101% sure. Hope you guys can shed to light to my problem.
john_carlo
ive check mine paps its center allign no problem at all... but im using 2.50 rear.. i think racingboy sprocket hub is the problem ive notice that some hub is differ in size especially the height in some kit that i install...
guitarizta
well maybe your right, will a slightly longer sprocket hub center my mags? maybe i should look for a y125z sprocket hub since my mags is for y125z labeled in the box when i bought it from sir @speedmaniac what do you think? do you have idea how much is the price?
john_carlo
yes paps because if you will alter the spacer in the hub rear spocket will not be allign to the front,, have you tried the rs100 hub.. or my way of resolving the proglem is putting a washer in the collar spacer insde the hub between the mags and the hub thickness is depend on the allignment of the mags then shaving the spacer in the rotor side according to the thickness of washer
guitarizta
not yet tried any other sprocket hub paps, your 2nd option is a little bit dangerous for me though. The space between the rotor bolt and the caliper bracket is already tight it might hit if the shaving is not accurately done. What is the feeling if the rear wheel is not aligned to the front wheel? I already traveled hundreds of KM with my setup but didn't notice anything wrong, its just that it hits my inner fender if i have backride. My temporary solution for now I moved my inner fender to the left side but still not totally free from hitting by the tire.
