Radiator water lagi ubos.
chiglai
sir docgabby baka meron ka extra dyan copper sheet.. need 1.. wala na kc nabibili copper sheet dito... mga xrm kc may benta na gawa ng highspeed.. sa sniper meron sana sa highspeed kaso 1mm tas 71-73 ung bore nya... hehehehehe
baka may extra kayo dyan bilhin ko nalang ung 57 lang bore out nya... thanks.. sensya na OT.. hehehehe
docgabby
ngek. have you tried auto supply? most auto supply sell brass sheets and not copper sheets. wala ba dyan gasket maker sa lugar nyo? those who cut out gaskets for engines? using copper, asbestos, and the like?
docgabby
ive seen a hispeed head gasket or plate na ata yun pang 60mm bore made out of aluminum. yup makapal nga. meron ata kami available here pang 60mm bore pero hindi pang 57.
chiglai
sir ive checked sa highspeed wala po silang 57mm and 1mm po kapal sa mga ready made nila... hahay i guess gawa nalang ako... hehehe hirap kc gawin ung holes para sa water passage... enways ty docgabby..
docgabby
kaunting tyaga lang sa pag gawa ng holes para sa water jacket. buy a puncher then punch away slowly. or maliit na gunting. malambot naman copper.
docgabby
a self made copper cut out copper gasket is not as bad as you think it is. its an additional interface between the block and head. as long as the head and block are surfaced well then its ok. have you seen precision make their "head gasket"? actually they dont use head gasket but just a copper wire ring! there is a groove for which the copper wire will fit and just gasket maker around the rest. the copper ring just serves as additional seal around the combustion chamber. so wag ka matakot gumawa ng sariling cut out na copper gasket.
