135lcSS said:
owh we can use our t135 standard sport rim with rear disc brake juz add the hub....cool then..does it fit..to our sport rim man..
oh sorry about that bro. i think its daytona mag.
but from local discussion it will fit with your stock mags.
what you need is to drill 4 holes to your mags.
same dimension with the hole in the hub.
that is where you will insert the bolts to hold it.
yo also need some rubbers for the space in between
the bolts.
no need to weld it, but you can weld it if you want.
go buy rs100 sprocket hub in your local store
its very cheap $3 i guess.
