mine has no head gasket too, just threebond. increase compression on my 60mm bore.![]()
sir,you removed both head and base gasket?mine has no head gasket too, just threebond. increase compression on my 60mm bore.![]()
i tried kawahara stage 1 cams with no base gasket on a stock bore...with no valve pocket. POG POG POG POG POG POG,, hehehestock bore stock cams. is it still necessary to have valve pocket if removing base gasket?
what do you mean by POG POG POG POG sir?..is it scary POG POG POG sound of your pipe or scary POG POG POG of piston hitng the valves?i tried kawahara stage 1 cams with no base gasket on a stock bore...with no valve pocket. POG POG POG POG POG POG,, hehehe![]()
what do you mean by POG POG POG POG sir?..is it scary POG POG POG sound of your pipe or scary POG POG POG of piston hitng the valves?![]()
