macoy said:
deadhungry said:
mga paps gud pm.. may tiktiktik sa makina ng motor ko. hindi sa head sa engine mismo paps pano kaya ito?
sakn din meron. tpos pg neutral pag nirev ko ng high rpm my lumabas n usok n puti.. ano kya un? sa piston?
magandang gabi po RPM!
check mo to sir!
-White smoke or semi white can be produced in several ways. One way is oil this is normally a whitish blue to blue smoke and has the apparent smell of oil being burned.
-Blue smoke is primarily from internal engine wear. If it's constant when the engine is on, then the rings etc are worn and need to be replaced.
-Black smoke is a fuel/air mixture suggestion problems with injection or carburation. Cause of black smoke is due to running rich in the fuel air mix.
-on a simpler term....
*Oil of any automotive type burns blue.....
*too much fuel issues burn black
*not enough fuel issues burn grey
*pweding may tagas yung oil mo sa piston trough piston rings..
-either sira ang rings/may may gasgas nag cylinder wall
*or overfill ng oil (800ml lng po..i know you this hehehe!)
-OVERFILLING THE OIL will produce this white burned smoke too. Yes, it will SMELL different. IT will also usually go away after some driving(mauubos din yan hehehe!). CHECK THE DIPSTICK, it's obvious, but do it--do it right. Flat surface; cold engine. Pull--Wipe it off--put it in--now you are getting the real level.(.... 8) ...)
*rejet carb(much gas/fuel being burned in the engine.) on your case since may tikitik mukhang malala pa..
have it fixed as early as possible...sana piston ring lang ang sira if ever para madaling palitan kung may gasgas cylinder wall..rebore/bore kit(wahihi!)
-kung stock engine po for me.. mas mainam po sa YAMAHA 3S shop(YZONE ortigas)
-kung moded...sa isang malufet na mekaniko
broom broom RPM...
