Rpm Hard To Drop To Idle
gunkhean
I just need some help here, recently I change my original carburetor to original mikuni VM30 carburetor, but after install it I realize that when I rev the engine then the rpm come to idle is quit slow, delay about 3 to 5 sec. I check the cable, it is smooth, is not a sign of cable get stuck. so any idea?
chie
try to replace repair kit of carb. i think the air fuel adjuster rubber had a problem.
and also clean your carb air passage :thumbsup::coffee:
JuNjUnETAS
Sir please help me. The engine of my Sniper is still stock but the problem is when I rev, the acceleration was delay.
chie
same problem with gunkhean replace your a/f o-ring thats is the cause of delay of your engine, and also clean your carb.
-also check your choke cable.
bhek_21
What is the sizes of Jettings and the setting of your A/F screw? I think it's a sign of LEAN mixture if I'm not mistaken.. Make your A/F setting quite richer..
gunkhean
I already change the air fuel screw c/w oring, but not original cause original cannot be found. The same problem occur.
Roy_LC5S
if you rev couple times and get different result with unstable idling, probably your hose leaking. but if that is not the problem, you could turn out your air srew for another round. it happened to me once.
gunkhean
Maybe u r right roy_lc5s, i need to check the intake hose, is a new intake hose from uma racing, hopefully will settle the problem.tq
z_ride13
may
maybe your cable is short for the new carburetor..try to see if your carburetor plunger closes completely..pull the spring to make it a little bit longer ..also try to turn your handle left and right if its accelerates more..so check if its not really cable.
