Setting Carb n Jetting
sspinalcord
Assalam.. lcv2 5s block 62 ikk, head std porting, sv uma, high cam ikk, cdi mb performance, exhaust open, carb uma pwk 30mm..
masa turun bukit lepas throttle exhaust letup letup laa..
Apa mj pj yang sesuai?
zorkorion
Setahu sy ada 2 sebab ekzos letup..
1 sebab MJ besar,
2 sebab AIS x tutup..kalau AIS dh tutup,maybe MJ besar..
Boleh try macam @adamshukor atau
PJ 32/34
MJ116/118
angin 1 1/2,
jarum no 2
Kamarul91
As salam bossku. Newbie psal lc modi nk tny Otai2 smua.Lc v2
block fz 57mm
cam std
S.valve std
CDi oren thai
Carb Keihin pwk 28
Ekzos std
Kotak angin filter uma racing
Pj38 mj120
Jarum takuk 3
problem moto skrg ada bobok cket gear 1 & top gear drop...Kalo lpas rembat pastu bhnti kt lampu timing jd rendah mcm nk mati...mohon tunjuk ajar otai2 mj pj brpe yg sesuai @ sbb lain..tq
adamshukor
block fz 57mm
cam std
S.valve std
CDi oren thai
Carb Keihin pwk 28
Ekzos std
Pj38 mj120
Jarum takuk 3
Cam dgn spring tukar masuk yg fz punye jgk.. lpas tu baru setting balik carb pj 34/32 mj 115/110
zorkorion
block fz 57mm
cam std
S.valve std
CDi oren thai
Carb Keihin pwk 28
Ekzos std
Pj38 mj120
Jarum takuk 3
PJ n MJ tu besar sngt..slider bulat tu ok la..nsr ke..kecikkn lagi PJ n MJ mcm bro adam suggest tu..boleh try 30 110 jarum takuk 1 angin 1 1/2
Alex_Jaybee
Salam boss . Sya msih newbie lagi psal mainjet ngn pilot jet . Kawan skrng tngh main Spec 57 Lc v1 , time nk bwa tuu mtor mcm nak mati ii .lepas nak berenti mtor trus automatik mati trus then susah nak start . Adakah mslh mj atau pj bosskur semua ? Boleh cadangkan Mj Pj kawan tak yg bgus utk spec sya.
-Carb 28mm
-Mj 120 Pj 38
-Ekzos open
adamshukor
-Carb 28mm
-Mj 120 Pj 38
-Ekzos open
Crb ape pakai tu?
Pelumba malam
Jauhla jgk... sebab set Btdc 29 cdi brt.. set highway n jln biasa... ni nk pakai carb lain pulk sebab bunyi kuat throttle valve...
Assalam ..bang nak tanya bunyi throttle valve tu mcm bunyi tik tik kalau tgh idle ke pastu pulas throttle xde bunyi tik tik..kes saya lepas tuka carb standart v1 ke taikom pwk28 ade bunyi tik tik..
Pelumba malam
Pelumba malam
Assalamualaikum semua..
Terima kasih atas semua ilmu yg diberikan sepanjang sy baca dlm forum ni terutama @man_sate , @Ayep6409, @Amy729 , [USER=17269]@ple5888 utk setting carb
Spec sy skrg
Block : SCK 62.5 mm
Head : std
Valve : std
Teppet: 0.7mm 0.9mm
Cam shaft : cms T2
Spring Valve : OKO
Rod : Koyo
Bearing : koyo
Clutch : Racing
Cdi : BRT smart Click(btdc 29,rpm 14.5) -dulu cdi uma pastu kong.
Coil plug : Uma
Ekzos : std (dulu ekzos uma semput)
Carb : uma 28mm
Intake: std
Mj : 118@115
Pj : 34@34
Takuk jarum : 2
Bukaan angin : 1 1/2 ( filter xpakai tutup filter cap, guna velocity hose SYS)
Plug : coklat
Gear : 1,2,3,4 ok
Spoket size : 15-36
Berat : 85kg
Top speed : 160 km (tegak)
Terima kasih[/USER]
adamshukor
Yer.. nk pasti kn pakai jari tekan slide crb tu klo tekan senyap mmg bunyi bnde tu la.. klo nk bg senyap cable trotel seting fit2 jgn ad gap nnti dye snyap sikit.. tp mmg ttp ad bunyi nye..
Pelumba malam
Terima kasih bang diatas info dan nasihat yg diberikan...terbaikk..memang hilang bunyi tik tik kalau tekan kt slide tu lepas setting ngam2 cable dengan carb ok dah..risau bunyi pelik2 ni kalau ade kt motor ...carb baru lagi .
adamshukor
Tk yah risau tkde pape.. mmg ad bunyi.. slide bulat je yg snyap sb berat dan fit.. slide d mcm pwk mmg longar sikit.. no problem bro
Royss
Assalam, mintak jasa baik otai ii moto,
Saya ada masalah setting Carb NSR dekat LC135
-Moto standard kilang
-Tukar Cdi Uma (with controller)'
-Spoket 15-36 / berat owner 60kg
-Ekzos std juga
Mj 135
Pj 25
masa bawak tak ada bobok... tapi top masih sama dengan moto std (Meter 125km/h- GPS 113km/h
waktu lepas trothle ada bunyi tik tik sama ada dekat clutch ataupun spoket
