akunyer bro cham belikan.....try tanyer bro cham kite....hehehehehtq broo malannn,,,,nk tnye dlu,,,tkut sold out dh,,,hehehek
dah ade jwpan dalm forum2 yg lpas.. xslap kna lay kri knan 1mm.. past wat lbang pin baru..nk tnye sikit otai2,,,klau nk pkai rod jaguh,,,nk kne lay ker crankshaft ???heeee,,,,,dgr citer klau nk pkai rod jaguh nie x ley pkai piston lc,,,kne pkai belang o jaguh pnye,,,,huuuuu~~~~
spark plug ko kaler ape bro????....aku mase pakai 60mm dulu pakai mj105 pj 32.....just sharing....asalam otaisan2,, dekat sini nk tanye serba sedikit pasal setting carb,, spec mto 60mm, cam shark, sv, pwk28 115 main 42.5 pilot ekzos custom,, nk tanye kenape trottle minyak jadi kosong mase gear ke 4 n pada half trottle,, speed dlm 130 je,, mintak bantuan kalian ttg problem nieh,,,
piston ade buat pocket valve????mase aku pakai 60mm dulu carb 28mm uma aku set mj105, pj 32 spark plug kaler koko gelap....just nice....leh la layan top speed tapi tak outmeter pun....hehehehehslm otai2 sume...ne nak tnya pndpat ne..sy tgh upgrade moto 135lc extreme spirit 5 speed member sy....tukar block 60mm,carb uma 28mm ngan cdi jupiter mx....saiz main & pilot jet apa yg sesuai??ne first time plak upgrade stakat 2kar block sa carb ja...yg len2 stnded gaban ja....lg 1,bla start ada bnyi tok3x...mmg sy tau 5 speed besa bnyi cm 2...tp kuat sgt..tkut valve kn piston......maaf la otai2 sume tnya solan yg besa2 je....kurg pnglman setting2 carb uma ne...
plug hitam karbon broo,, heheh,, suspek mcm cdi kong je,, sbb tgh maintain speed api twos xde,, tp da solve prob tuka block fz 57mm, carb std, highcam, cdi std, sv,,, tp mmg trottle berat ehh klau gne carb std? bg recipe sket boss,,, pilot ngan main gne brape utk carb std pekak gne block fz nieh,,, pastu jetting carb std gne pilot jenis ape ehh,, sorryy nubiess here,, lc v1,,spark plug ko kaler ape bro????....aku mase pakai 60mm dulu pakai mj105 pj 32.....just sharing....
nak tye carb pe28 pakai pj n mj ape ye yg same?
utk blok saiz 63mm mj n pj saiz bape yg cun?
mohon pendapat kawan2 semua ye
TQ !
mkum bg nasiht cikt,,Setting utk pikap.
Blok 65mm
Stroke 65.7mm
Carb UMA 34 130mj 38pj
Head hispeed 22/19 camshaft Kawahara k2, ejos custom.
Set lama dulu2
Head hispeed 22/19 hi compression, camshaft rideit
Carb pwk28 mj 118 pj32
Ejos custom.
Blok 62mm
Lagi lama punya setting
Head hispeed, std compression, camshaft rideit
Carb pwk28 mj 115 pj 32
Ejos custom blok 60mm
nak set carb rzx,,,mj 185 pj 22.5 time parking bunyi da cun,,time da nak jln gear 1 bunyi semput hbs,,mcm x larat da mtr tu jln,,,tgk plug basah,,tadi aku baru check plug... bagi aku ok kot hitam kering...
