Setting Carb n Jetting
Paan111
Nk tnya...blok 63 head standart porting caburator oko pwk...pilot 38 main 130...bila bwk pulas 3/4 mcm tu bobok2...saiz main pilot sesuai
Arinzulkefli
Salam bos.. Saya pakai(spec fz) cam std lc spring valve std lc
exzos 28 cutting std
Head poting sikit
Carb nsr 28 mj135 pj 34
Cdi std
Msa saya pkai cdi std plug hitam..
Lps tu tkr cdi arata plug trus cantik warna perang.. Sbb cdi atau bnda lain.. Lagi satu nk kne trun lgi ke mj pj.? Saya rasa mcm besar sngt.. Ap pendapat tuan?
syahyin90
Salam berapa base jetting untuk uma 30mm
spec motor
block 63 cms piston flat
cam g1
head std porting inlet dan oulet dh besarkn
ekzos espada cuttg std 28mm
cdi brt dualband
susah plak jetting uma 30 ni.
masa pakai uma 28mm
pj 34 mj114 jarum atas skali
afr cun. hp 21.9
Salam sifu² sekalian...tmpg tya...moto sy lc v1 spec 63..head 22/25..carb nsr pj 38 mj 125..ekzos standard modi..msalhnya carb xbleh koyak habis..hujung xdpt..mntk tlg tnjuk ajr sifu²..
Masalah mcm ni. baik pg run dyno, cek AFR. Ada graf dia baru nmpak jelas, bila power turun. hahaha. Aku kes carburetor ni, 2 kali jem, sekali overhaul.
Pali85
Tq²sifu alhamdulillah...bru try td..mj 120 pj msih sma 38..cuma gear 4 ja mcm berat skit...esk up spoket skit...
Ayep6409
[/QUOT]
blh je pakai mj saiz 125/130 kalau nak cari top atas hiway,lg lah moto tu blh g lg.kalau kwsn dkt atau jln pendek x d saran kan nanti mkn plug.spoket kena cari yg sesuai.kala kecik sgt nanti top lemau..
Hhhh9994
minta suggest sifu sifu...
kalau spec block 65
superhead 22/25
gearbox 1,2&4
carb uma 32mm
ekzos ahm m3 32mm
jetting mj & pj start dari berapa?
Kuman
Salam para ii old sifu kita, mohon bertanya
Block suprimo 63, cam gsm 3, head leo 19/22 porting, carb sck 28, coil plug racing, rod ikk
skrg pakai pj 35 mj 124 uma pickup memang melambung (boleh dikatakan sedap) tapi long mcm tk berapa nak smpai (top kurang sikit) , ingat nak set minyk lebih sikit bagi long sedp ingat nak beli mj 128 uma atau 130 uma, mohon bantuan agak ii mana sesuai 128 atau 130 trus ?
FitryPenang02
Salam dan selamat petang, nak tanya moto spec fz, coil plug uma, cdi oren bila pulas throtle separuh rasa sikit bobok, kena pulas slow2 saja. kalau masalah carb macam mana nak setting size mj/pj carb nsr. plug ada putih. sekarang mj140 pj 27.5
Ayep6409
Letak pj saiz asal 40
Ayep6409
Cam gsm 3 x besar sangat ke..cr kena main tinggi baru hujung xlayu di hujung mekar
Pojhe
Salam semua. Motor saya lc 5s spec fz basic (block piston cam). Yang lain2 semua standard. Sebelum ni motor ok bawak sedap, pick up dan top pun ok. Baru2 ni saya tukar ke ekzos y15 standard manifold 28, tapi motor jadi mendap pula. Respon pun kurang.
Boleh suggest tak mj pj untuk carb standard ni? Sekarang pj 15 mj 120. Kalau boleh jangan la suggest tukar carb, xde modal lagi. Thank you in advance.
