Shell Helix Ultra on Motorcycle.. Is it harming my bike..?
Mas Catoer
Guys,
My son did me a favor. On his way home, he replaced the engine oil with Shell Helix Ultra 5W/40. (USD 16). The previous oil was Shell Advance Ultra. After browsing out some sites and read the Shell oil guidelines. I realized that Shell Helix ultra is for car's engine. I totally don't know what to do as once my son texted me the oil was already filled in. But one thing I should consider that my son insist that the oil package has bike picture on it.
Just your opinion: While Im searching for any references, should I dry it out? Run it and see what happen..?
Here is the oil Spec:
API SM/CF
ACEA A3/B3/B4
BMW LL-01
MB 229.5
VW 502 00 / 503 01 / 505 00
Renault RN0700, RN0711
Porsche Approved
Ferrari Approved
SPEED RACER
Guys,
API SM/CF
ACEA A3/B3/B4
BMW LL-01
MB 229.5
Porsche Approved
Ferrari Approved
shell helix ultra is not good & not recommended for 4 stroke engine, your clutch lining well burn easily
shell advance ultra is for 4stroke engine and it is good oil and quite expensive..
Mas Catoer
Thanks for the reply, Bro.
So far that I've noticed that Shell Helix Ultra is for four-stroke engine. But, it aimed for latest car that having all advanced tech. :)
I use Shell Advance Ultra for few month. Initially I get used to having Motul Ester for 8 months. It was good actually. But I wanted to have experience with Shell and I got it twice, with significant performance. But at last my son dont really clear about the terms "Advance" and "Helix" Then, instead of doing me favor he did make me got a headache... :(
undeadx
engine oil for motorcycle is generally different than oil for car. for motorcycle, the oil also lubricate the gear/clutch and it is designed to minimize clutch slip and so on from my understanding.. motul 5100 is the best that i have tried although its more expensive than what i usually use..
Mas Catoer
Bro. I've been with Motul for more than 8 months. It was perfect. Then I tried Shell Advance Ultra 10w/40 (priced almost double the Motul). I felt it slightly different, then I decided to use it for few more months. He he he but my son didn't really notice my word "Advance and Helix" then he randomly picked Helix..!! :(
Yes, I've been reading debates around Oil for bikes and its relation with friction modifier. Clutch slip is always the main reason in choosing the proper oil. But, sometimes I see the simple pictures in 80-90's where all bikes use the same oil with the cars, I found it worked totally well.
Today I tried to run the bike [ on my own risk :) ] up to 130 km/hour while watching if the speed is well synchronized with the tachometer. From low to high RPM it showed me no indication of slippage.
Then I stopped by at an oil shop, talked to same bike mechanics. The amused me by saying it's OK to work with Shell Helix Ultra.
God..! Hesitation really caught me even more.. :D
undeadx
if i mistakenly or accidentally put engine oil for car in my bike and its working fine, i would revert back to engine oil for motorcycle at the next oil change because it may work fine for a while but in long term, it could cause damage to the clutch/gear parts.. at least good to know that the bike can run on engine oil for car, save me the troubles if the same things happen to me.. ive read that yamaha t135 doesnt like shell engine oil, never try shell engine oil before so i dont know if its true or not.
Mas Catoer
I agree with you, Sir.
Reverting to its proper oil is a must. I'll have it done soon on the next scheduled oil change. :)
For the time being, I just need a reasoning on this mess, so that I can go on with this wrong oil safely to next oil change (in which may wait for another 2000 km) :( This morning some friends said its OK but try not to make frequent speeding, as the engine heats up things around wet sump clutching might become unpredictable.
Wise advice I guess... :D :D
