langis yan paps, galing sa hataw yung sniper ko ng nag plug reading ako nyan, pero pag normal na takbo, wala naman yug langis,may langis paps ung thread ng plug?..basang basa yata..o gasolina ..
nakaside gapped po ung sp ko sir nung nag northloop kami.side gapped stock SP nakareserve
tried it once -short ride no difference with Denso IU-24
which means it's comparable to special plugs like iridium
still to be tested for long drive though 50kms at least non-stop and no switch off
of the ignition
talagang maganda ung performance..
walang problema.
good luck sir.anyone tried side gapping an iridium type sp, cuz i just did it & by clumsyness i removed the tip.. so here i got a sp side gaped without the iridium tip, but i still installed it on the bike just to try if will it work & it works fine, the warm up of the engine is faster, im gona take it for a ride to see what happens
paps pa explain naman ibig sabihin mo dito,pag dumami rust sa head at piston ok yan pra sumabog ung makina
haha, di ko alam kay papa jeff if anu ibig sabihin nya. baka napasukan ng tubig ung loob..paps pa explain naman ibig sabihin mo dito,
possible ba na mag ka rust ang head at piston dahil sa sp gap?
,kasi how come na mag rurust ang head dahil lang sa sp?.UP!ask ko lang po if natry nyu na mag side gap ng sparkplug nyo? ..side gap user here.. share ko lang to..http://motorcyclephilippines.com/forums/showthread.php?t=216989&page=9
As you can see the ground electrode is blocking the fuel expansion, you want it to hit the freshly entered fuel, not the exhaust side where some exhaust gases are still left over. Plus side gaping allows for the flame front to go down, thus helping it expand faster.
Tools
- Sharpie
- Dremel or something to cut metal with precisely
- Spark Plug Gaping Tool
1. Remove your spark plugs from the engine or if they are brand new take them out.
2. Take a sharpie and mark the amount that you want to cut off.
3. Properly bolt down the spark plug so that you don't have to hold it by hand when you use the dremel.
4. Now Dremel sells cutting bits, you will need one of those, they cut through the ground electrode like butter![]()
5.All done with the cutting
source:http://www.sr20-forum.com/naturally-aspirated-all-motor/16898-how-side-gap-spark-plugs.html
ung side-gapped SP ko sir eh almost 2 years ko ng ginagamit,, stock sp ung ginamit ko.Gaanu ba itinatagal ng side-gapped SP? How long will it last?
Is it recommended for daily use?
Anu anu pa bang adjustment after installing it?
Im planning to use it eh..
TIA![]()
pang daily use yan sir,hehe, napang long ride ko na rin,walang problema, it gives more power and fuel efficiency.
-learn more go to the link i posted above, sa MCP yan sir. thanks po.
alam ko sir as long na tama po ung side gap mo ok,hehe,, tsaka reminder lang po, mag aadjust po kayo ng air/fuel and ng idle screw, kasi mag iiba response nung kuryente.. "lalakas po kasi"tanong ko lang paps kong pwede, din ba gawin yan sa spark plug NGK IU24 IR?
