Siti!
Sonnyjha
@sidro
last December 15, 2011 ko lang nadala ung MC ko ng sta.maria bulacan..January 5, 2012 kona nakuha 3weeks in da making dami kasi holiday badtrip sarado lahat ng racing parts strore plus precision office sarado din dat time..dpat 2weeks lang tlaga ginwa ung sakin..kaya break in palang me till now..
rowan
i used to have 61mm lhk brand paired with cy head lhk raider valves before. i do d italian way of break in too.
after 1.2k . wala nman xa gasgas. later on may nagka gusto i sell it sa mga drag racers sa amin.
brother dex usually when u do the 60mm plus mods some things u have to do daily basis esp on break in
-oil level (daily kc khit vixion hindi umubra pag kinulang sa oil)
==check plug color once in a while
===stock valves is ok but on 60mm plus u need bigger valves
boldstardex
before and after nangyari ang siti bro i checked the oil level and nasa normal siya, the plug color was also normal (golden brown),
sniping area gumagamit ng cmr 61 almost 1 yr na and no probs using stock valves
macky free using shark 62mm almost 1yr ok din using stock valves
rowan
sinuwerte lng cguro ang block mo,cguro signs din yun dika ntuloy kc malay mo theres danger ahead.:)
tama nga papa thops next upgrade puhon puhon as u have said
pano ba yung italian way?
yun yata yung kung magpatakbo ka parang si rossi :p
Probable causes:
1.)Oil: hindi nka penetrate ang oil dun sa liner ng mabuti(im using top 1 part syn)
part synthetic?
hmmm when breaking in an engine dapat standard oil lang para mag wear ang bore ng normal (breakin process stage)
if you will use fully synthetic or part synthetic that means less wear (breakin process is less)
me for newly bores,
i use yamalube for the first 5000kms on vixion kit (500kms &1000kms change oil) + hard breakin = then fully synthetic na after...
so 1000kms odometer + part synthetic oil = kulang pa breakin process
OR
talagang minalas lang..
ganyan talaga pag mag mods :) wish wish lang hehehe
jimpie
runway ng eroplano
siti!
story:
after 1 month and 1k odo meter,(s0ft break in) bumigay ang cmr 61!:p
nangyari eto while papunta kami sa agusan running aprox 80kph on third gear.
Probable causes:
2.) kulang sa break in (which i doubt)
3.)pipe elbow too small (im using dbs slim elbow)
4.)na malas lng talaga sa bore!:p
remember: ang pag momods ay isang sugal, win or loose lng yan..walang maybe...hehe..happy moding guyz!:)
tama ka dyan paps ang mods ay sugal lalo na pag gusto mong matoto like :D
jimpie
me too 2 yrs ko din nagamit ang cmr61 bore.
w/ cyl bore honing hardbreak-in agad ginawa ko...hataw mod:D
bumigay lng cmr ko ng masira ang conrod bearing ng mc ko.
paps dba sayo yung nasa youtube na video yung parang sumisipol na parang ewan yung makina mo. ano bore gamit mo doon at ano problem nya bakit umingay ng ganun? ganun kasi dinaranas ko now :D
jimpie
bro tsek mo din conrod bearing mo baka may wear na din kaya nagkaganyan ang cyl bore ng mc mo.
kung may tiktik sounds ang engine ng mc mo malamang palitin na din ang conrod bearing.
paps post ko lang video mo ha... ito yung nakita kong video na kagaya ng name mo
sacker42
conrod bearing yun bro. nagpalit kc ako ng conrod pang mio ng d ko pinalitan ang bearing, kc sabi sa machine shop ok pa daw bearing ko:( sablay yun ang resulta tikitik sounds.
sacker42
bro yan yung dati ko pa problema sa engine ko. loose timing chain yan. nagdagdag kc ako isa ngipin sa timing chain tapos tensioner ng rider gamit ko. d pa din nawala ang ingay dahil sa chain loop.
jimpie
aww.. yung sa akin kasi maingay sya parang typewriter sa loob pag tangal ko ng head at block ko puro kamot yung block ko pero ginamit kuparin kasi medyo hindi namn salat yung kamot pero maingay talaga. at malata manakbo kaya ito ipon mode muna :(
jimpie
ano ginawa mo paps para mawala ingay?
thopiang
check ur cam bro
sacker42
eto ngayon bro nagpalit ako ng conrod pang mio mas maiksi ng 2mm sa stock conrod ng sniper natin para balik ako sa stock timing chain. naka 1.5mmpin kc ang mc ko tapos 61mm lhk bore gamit ko piston pin 15 (mas mahaba ng 2mm ang piston-distance of top of piston to piston pin)
