bart99
ThanksBart99, see post #6 of this thread.
@ christopher sir naka cable tie lang sya. pero pwede gawan ng bracket yun since kasi malapit sa brake panel bar stopper. yung humahawak sa brake panel. para di na kailangan mag welding.
sir, may pic po ba kau na kita ung under ng mc? para know ko if ok cxa kahit dko tangalin ung stock fender para kapag kabit ng tire huger eh swak ba or hindi?? sorry sa OTor you can just lift your shock... but the height of the seat will also extend
pag naka FE kana wla na. pero sa stock fender may babawasan pa.thanks kc nakita k ung MX may nka welding dun sa swing arm eh.. kaya ask ko po.. pero ok nmn po ba cxa once ikinabit ung tire hugger ng MX?sakto po ba cxa walang ttamaan na anu dun? kc balak ko lagyan many tanks po
Any time, sir Traxx. As long as there is good info to share.great info bro!
You have to remove stock fender. Otherwise both stock fender and rear tire hugger will definitely hit each other during up and down movement of the swing arm. Use your creativity to make mods on how you can keep and hold the tail light in place. Also, find a way to make the right and left side panels a little far apart to make allowance on the upward movement of the rear suspension.p
ok many many thanks bro.. nice info ride safeYou have to remove stock fender. Otherwise both stock fender and rear tire hugger will definitely try hit each other during up and down movement of the swing arm. Use your creativity to make mods on how you can keep and hold the tail light in place. Also, find a way to make the right and left side panels a little far apart to make allowance on the upward movement of the rear suspension.
As for the installation of the inner fender, attach it to the swing arm with original bolt and nut in its original location. For the right side, in my case, i secured it using a single cable tie. I did not want to weld on that side of the swing arm.
I hope you got the whole idea correctly. Goodluck!
I never ride on the wet.pa OT po ask ko lng kung nka FE ka tapos naka tire hugger ka wala na bang talsik sa likod ng passenger?
magksama na sila paps...mga paps ask ko lang...kasama ba nyan ung chain guard o hiwalay
nice paps balitaan mo ako heheheIm trying to ask here in Yamaha 3S Rosario if availbale tom![]()
