Sniper Mx Modifications
bhek_21
3rd gear for 80kph?..15/38 3rd gear almost 100kph..as a whole I could run w/my sniper mx on 140kph..all stock..
Yes sir.. How fast can you get 100kph at 3rd gear? Me, I'm already using Keihin PE27 but my CDI already limits me at 80kph in 3rd gear, I can't give exact time figure but it's quite faster compared to stock..:D I'm satisfied because I'm not after for top speed..;)
bhek_21
yes i agree but i think u will need more time and longlong road for you to reach 140 and maybe f you are 50kgs..hehehehe:)..its possble
I agree with you sir because at 15/38, you are sacrificing your acceleration but good high speed at long stretch..;)
I'm 72kg, and I think it is not applicable for me in addition that here in pasig is prone in heavy traffic that's why I focused on acceleration..;) But it's not quite bad.. I'm planning to install RCDI, it will make my RPM limit longer..:D
buko0
are you sure sir? my acceleration is still sacrificed at 15/38? then, whoaw. :eek:
i am very satisfied with the acceleration of my stock mx (except for open pipe)
but then maybe its because i'm just 45kgs. :D
bhek_21
Yes sir.. There are many things to consider in sprocket combi.. riders weight.. Engine mods.. Riders preference.. terrain.. etc..:)
yes,its true that 15/38 is not good in starting but it is in stretching..it is truly stock but it depends on how you take a good pulse interms of riding,ryt?
buko0
so then if i change my sprocket combi that depends on my weight then.. whoaw. :eek:
in the stock combi i can easily reach 110kph in less than 100m road in a normal riding position, all stock except NOB1 tribold, or i just dont know how to correctly measure the road. but i used google, is that acceptable? :p
bhek_21
Sprocket combination is trial and error sir.. It's according to your preference if you want top speed or acceleration..;)
bhek_21
Guys I have a question.. There is a tire information sticker on our front fork housing, left leg.. On the bottom left and bottom right, Does it says "YAMAHA SNIPER"?? Please post a clear picture of this.. cause I'm doubting mine..:(:confused:
egmusngi
ang tulin ng mx mo sir,,congratz...all stock,dati,na try ko 90kph 3rd gear,, nglilimit na ang cdi..ngayon modified na ang engine ng mx ko,,halos magkasingbilis lang ang satin ^_^...
ianghol
has any one tried to der smx the kawahara black cam?..what is the jetting in your stock carb?..and if somebody here know where to buy jetting for stock carb of smx..:D,,thnx
