Sniper Mx Modifications
John Jordan
About to try it out sooner or later and see the results, but so far I kinda like the pick-up. BTW, I bought an engine sprocket 15t for RS100. Do you think it'll fit? :D
John Jordan
Alright! haha. BTW, hope you dont mind sir, whats your advice, since I would like to increase my mc's power w/out boring up. RCDI, VS, Cam, ignition coil, etc.
saintDave
Stock sprocket combination much better.. My mc top speed 130kph all stock. when i changed the mode of my mc i change it to 14/38 it almost same as stock but i top at 160kph this is the load of my bike crg cluch spring, oko flatslide carb 28, pj 39 mj 112 rextor cdi uma high cam, jvt v.spring yun lang po stock bore is powerful
good day sir.. i have problem to my valve clearance. coz i dont know what exactly valve clearance of in__ and ex__???.. i use uma high cam and SPS head 20/22 bigvalve and highspeed valve spring.. and 62mm bore xray ceramic.. can u help me to fix it.
raziel
What is the best sprocket combi sa 50/80-17 front and rear is 60/80-17 all stock? And is it true that on smx u dont nid to change the valve spring? Direct rcdi and 28mm carb without v.spring change?
jangbest
Huh!!! Who says that ? Direct RCDI w/o Changing your valve spring ....
Dont listen who ever tell you that info! That is the number 1 rule you need to change your vspring when your using RCDI. or else kaboommm engine ..
raziel
@jangbest thanks kuya i'm scared that's why, i have my new smx and i wanted to change my v.spring but its just a month old..because my brother told me that they will open my machine for it to change the v.spring. are there no other option aside from changing its v.spring like the other mc's just change carb and use rcdi?
jangbest
Your welcome Bro!
Let your engine be brake in before you have engine mods "just an advice". enjoy first your all stock smx.:):):) ...
albertwen12
Wow, you guys are lucky! My mx wont reach 120kph. What a bummer! Even with an open muffler. All stock. :confused:
Just seek for advise dre. at first I just dream of this top speed of my mc but whith some help of our masters here and some effort you might eventually see what our bikes are capable of! ridesafe--
albertwen12
can u give ur current set up sir?.. tnx and can u include ur weight?.. congrats for achieving that speed.. :thumbsup:
  1. Reached 155kph twice and gaining more, I'm just afraid of the strong vibration of the machine because of my sprocket combi maybe.
    Here is my set up sir, hope it may help you:
    BRT DUAL BAND RCDI
    CMS VALVESPRINGS
    FAITO ADVANCE LOWCAM
    15-42 sprockets
    namban pipe
    stock carburator and jettings
    smul man driver wiht 52kg
    of course smul tire sets and a rim sets. hehe :D
    just super stock and with the help of our masters advise ridesafe--
albertwen12
SAKTO! tama! agree sir. my stock intake valve springs got damaged and my valves deformed after changing my cam to racing and cdi to rcdi without changing the valvesprings to stiffer primarily. I have to bring it to yamaha center at bacolod just to fix that and believe me it cost me a heck of a cash. You are damn right sir! valve springs first. ridsafee--
jangbest
That what you call valve float ....;););););):thumbsup::thumbsup::thumbsup::thumbsup::thumbsup: ....
juanbaktaz
    • Reached 155kph twice and gaining more, I'm just afraid of the strong vibration of the machine because of my sprocket combi maybe.
      BRT DUAL BAND RCDI
      CMS VALVESPRINGS
      15-42 sprockets
      namban pipe
tnx sir :thumbsup:
