mine is also super stock set up but with "KALKAL" stock pipe. .too bad OPEN PIPES are prohibited here in our cityLol, that's right sir I forgot the pipe.![]()
Im so Satisfied now using my uma racing cdi. And vixion valve spring tipid mods lng me...can reach 130kph may ibubuga pa kaka testing lng hrap mka tyming. marcus highway mrami pa sasakyan dko ma full throtle
Have you tried 15/40 bro? We almost have the same set.What is the best sprocket combi sprocket for my Sniper Mx?. My set is uma 62mm, stockhead ported, dual band cdi and pe 28mm. Tire is 120x70R and 90x80F. My weight is 95kg. My present sprocket combi is 14x36. Thanks!
bro, what is your current sprocket right now?Hi mga papa...what is the best sprocket combi of this set
UMA SUPERHEAD + UMA 62mm bore + 28mm carb UMA
currently i'm using 14x42 which is not good for the above set.
sir, is your friend on rimset or stock mags with that sprocket combi?my frnd is 62mm + 22/20 big valve + 30mm sunworld D-slide. he's sprocket combi is 14-36. try sir. ganda response same with relax engine.
re adjust A/F mixture or change your current jets..Patulong naman po mga idol, ngpalit kz aq ng keihin 28mm roundslide, prng sigok xa sa hangin kapag nirev mo xa ng prng nabubulunan. ano po mgnda gawin? TIA.
try 35 110what jettings is best to be used for this? all stock. except carb. Thx!
re requisite ang valvespring paps pag nag RCDI . .Sir mag change ako ng rextor cdi okay lang buh stock yung valve and valve spring?? Or baka mag float yung valve??
better change your valve spring if you will change your sprocket combination like 14 40, 14 41, 14 42 and 15 42. but if you're planning to use your stock spocket it's okay...Sir mag change ako ng rextor cdi okay lang buh stock yung valve and valve spring?? Or baka mag float yung valve??
Thanksp
re requisite ang valvespring paps pag nag RCDI . .![]()
Thanksbetter change your valve spring if you will change your sprocket combination like 14 40, 14 41, 14 42 and 15 42. but if you're planning to use your stock spocket it's okay...
So if bumili ako ng valve spring tska cdi paps walang problema?p
okay na okay na yan.. kahit babaran pa.. wlang problema. ride safeSo if bumili ako ng valve spring tska cdi paps walang problema?
Yes, you can have a modfied looking stock pipe and be "ok" for not losing your load. Obviously you wont get max performance but it wont be so bad as many people do that as they get tired of feeding the buyas on the street cornersHi gud eve everyone..
Just want some opinio.. Im using 62mm + bv.. Just wanna know if i can still use modified stock muffler or what they call "kalkal pipe" here in the phillipines...
Wanna experience some quiet life with out giving up my load.. Haha...
Tia
. I have got caught 4 or 5 times, but only fined once so i just keep taking my chances or ignore them if they motion for me to pull over,,, so far i haven't been shot at
