I'm not sure how the percentages are computed on your Uma Digital Speedometer but I have experience with the Koso Digital Speedometer for Mio and the percentages are usually on the manual. To measure your actual tire circumference, make sure you mark your front tires with a horizontal mark usually on the rubber. This will be your start and end mark. Now to measure the circumference, line the mark on the rubber (at the 6 o'clock position) and make a mark directly on the cement lined up with the one on the rubber. Move your bike forward until the mark on the rubber is pointing at the 6 o'clock position again. Mark this on the cement. Now the length of the start and end marks on the cement is your tire circumference. You just get this using a tape measure, use the formula that may be on the manual and convert this to the appropriate percentage. Set the percentage on your bike and your speedometer should be reading your speed as accurately as possible.
Ride safe!
