SNIPER, SPARK, CRYPTON X, EXCITER - T135 BIG VALVE HEAD
haen
Hi, Bros and Sis
Something to add the juice is coming..
1. BIG VALVE HEAD for T135
perfect couple for stock block (21/18 setup),
gives more power with Vixion block, 60 mm and 60.5 mm block
First Flavour : 22/19 Big Valve Head
BIG VALVES 22/19 config.. RESQUISHED..
Second Flavour : 22/18 and 21/18 Big Valve Head TK Racing
BEST FLAVOUR :
up to 64 mm block POLYQUAD CYL HEAD 23 - 21 IN, 18 - 19 EX with special job.
starting 65 - 70 mm POLYQUAD CYL HEAD 25 - 23 IN, 20 - 21 EX with special job.
2. AVAILABLE TOO for STOCK BLOCK :
TK RACING VALVES 19/17 gives more power and torque (based on dyno tests increase max 0.9 - 1 HP)
COMBINE this with TK VALVE SPRING.. feel the additional power and torque !
23/21 CONFIG IS AVAILABLE TOO, JUST PM ME
as usual :
ask price and questions by PM please, as this is a for sale thread.
payment method : PayPal, Western Union/MoneyGram, Wire Transfer
contact pm or YM id : haentiara
Thank you.
haen
The stuff would come in a few days, here's the preview of the TK Racing valves... THEY'RE ALL SWIRL POLISHED.. UNDERCUT STEM..
See the angles...
haen
@traxxas : hi good boy.. LoL.. still tweaking tat cool TMR-MJN ?
The difference between stock valve :
1. Material
2. Valve profile
3. Valve finishing (sandblast like).. look at the tip
4. Valve diameter (+1, +2)
5. Non magnetic characteristics prevents foul build up
In general, it's already made to increase the gas flow, compared to stock.
Also, the 19/17 is PLUG & RACE .. lol.. no hassles..
vnduck
Why are you doing this to me!!!?!?!?!?! :shock:
Seriously man, keep doing this and u will never get my package out of the way because i just keep adding new stuff into it!!!! :evil:
hehe
haen
@vnduck : hahhahahahah.. dont worry.. it'll be on ur way this week and be the first to taste it... thanx
justkir
yeahhh....i also feel that way...muahahha
haen, if i may ask, what type of material of the head? same like oem?
haen
dyno chart results from local tabloid for TK VALVE review..
increased peak power and torque.. this is just using stock valve size..
haen
HI GUYS and GALS, this is a dyno test result using VIXION STOCK KIT and BIG VALVE HEAD (22 mm and 19 mm config), taken from the courtesy of my friend.. u can see that with optimum tuning the result is awesome.. the only mod done on the bike is only carb change using PWK 28 mm and Big Valve head...
BEFORE BIG VALVE UPGRADE
By haen1974 at 2008-09-15
AFTER BIG VALVE UPGRADE
3rd GEAR
4th GEAR
max power changed from previous config (shown above) using only PWK 28 carb and Racing CDI, from 18,7 HP @9200 rpm and torque 14,63 Nm @8189 rpm to 21,9HP @10215 rpm and torque 16,44 Nm @8606 rpm, a difference of 3,2 HP
Will post the BIG VALVE HEAD TK RACING 22/18 setup results soon...
haen
STOCK SIZE TK RACING VALVE 19/17 .. look at the angles and profile..
COMPARISON BETWEEN 22/18 (left side) and 19/17 (right side)
haen
TK RACING BIG HEAD... take a look at this baby...
22/18 Racing Valves..
VALVE GUIDES.. 5 mm diameter valve compared to 4.5 mm STOCK.. stronger valve..
One more shot..
haen
DYNO RESULTS FOR THE TK RACING VALVES
Here's our dyno results on the TK Racing Valves.. tests performed with this config :
Keihin PWK28 KX100 (tuned up by Thole)
Cheetah Power CP450 programmable CDI
TK Racing Valves 22/18 setup
V-Ixion Block and Piston
STOCK CONROD
..bro Sydney.. thanks for the help bro.. !
Our little research proves that we can have durability (57 mm vixion block) and power resulting in..
23 HP !!
Top Speed (on Dyno).. > 150 kmh
By haen1974
By haen1974
4th GEAR
By haen1974
Mafiaflix
your welcome bro.., with all my pleasure thanks for this project.
Next project is 169 cc tune with big valve head.
guess/target it what horsepower will you get from this mod..??
