SOME PROVEN TIPS and TRICKS for T135
haen
HI GUYS and GALS, this is a dyno test result using VIXION STOCK KIT and BIG VALVE HEAD (22 mm and 19 mm), taken from the courtesy of my friend.. mr. Sydneys... u can see that with optimum tuning the result is awesome.. the only mod done on the bike is only carb change using PWK 28 mm and Big Valve head...
BEFORE BIG VALVE UPGRADE
By haen1974 at 2008-09-15
AFTER BIG VALVE UPGRADE
3rd GEAR
4th GEAR
max power changed from previous config (shown above) using only PWK 28 carb and Racing CDI, from 18,7 HP @9200 rpm and torque 14,63 Nm @8189 rpm to 21,9HP @10215 rpm and torque 16,44 Nm @8606 rpm, a difference of 3,2 HP
OTHER NOTE :
On my bike fuel consumption on 10 - 15 valve clearance setting is about 40 - 45 km per litre (stock config without BIG VALVE HEAD)
tatsing85
qsn on ais.... which tubing do i take out n which to close??? and how to close?? with wat to close??? anybody here with pix to show??? thanx
goff_d_p
your talking about tip # 3 right. ok, on the air box if your sitting on the bike it's the left side of the air box. just unplug the hose and add a separate filter to that hose, the plug that you pulled it from. all you need to do is find a rubber cap, you should be able to get one from any auto supply shop with a lock ring to tighten the plug. ok?
tatsing85
thanx dude.....so its just adding a separate filter... i tot plug ogg the whole hose conected to the ais and air box... heeeee
goff_d_p
i found it best to buy a new hose long enough to put the small air filter on the other side of the bike next to the radiator.
chiglai
and its positive effect?
goff_d_p
it is still the same as if you just use the stock hose. i found it kinda hard to locat the filter i got for that size hose to fit on the left side engine bay. thats why i moved it to the other side.
chiglai
1 for his cdi.. 1 for his horn.. 1 for his hid... 1 for his ignition coil.. and 1 for his piston???? hahaha
do we need relay 2 ignition coil???but 2 the piston..i know that IMPOSSIBLE n a bit nonsens...hehehehehhe
JUNEX
@phl6684 no chiglai is just joking. :D i wont add relay to my coil, HID, piston & cdi. by the way how much is the fare going to Malaysia from phils?
